Local Time 09:41 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Bug report
Seco
Posted: 07:42am 20 Mar 2019
Hi All (though this is probably directed towards Geoff...).
I would like to report a MM bug.
Issue: If a subroutine that has no parameters is the first command on a multi-command line (ie - commands separated by colons),
and the colon immediately follows the subroutine name, the subroutine is never executed.
Sample code:
option default none
option explicit
option base 0
? mm.ver
t2 0
t1:t2 1 ' t1 is not executed
t1:t2 2:t1:t1:t2 3 ' first t1 is not executed
t2 4:t1:t1 :t1
t2 5
t1:t1:t1:t2 6 ' first t1 is not executed
t1 :t1:t1:t2 7
t1 :t2 8
t1: ' t1 is not executed
t2 9
t1
sub t1
? "This is t1!"
end sub
sub t2 t as integer
? "This is t2: "+str$(t)+"!"
end sub
The output produced:
> RUN
5.0501
This is t2: 0!
This is t2: 1!
This is t2: 2!
This is t1!
This is t1!
This is t2: 3!
This is t2: 4!
This is t1!
This is t1!
This is t1!
This is t2: 5!
This is t1!
This is t1!
This is t2: 6!
This is t1!
This is t1!
This is t1!
This is t2: 7!
This is t1!
This is t2: 8!
This is t2: 9!
This is t1!
Edited by Seco 2019-03-21
Posted: 08:46am 20 Mar 2019
The interpreter considers your first t1 as a line label
t1:
Line labels don't get used much now with subs and functions being available but they are still there.
Seco
Posted: 09:01am 20 Mar 2019
Thanks Jim.
As I only use line labels rarely, and always put them on a line by itself, I did not think of the subroutine name as a line label...
Makes for a bit of possibly confusing syntax - I wonder if it would be possible to check if there is a matching subroutine name and if so treat it as a subroutine and not a label...
One for Geoff to think about (along with all the other requests he has!).
Gerard
KeepIS
Posted: 05:11am 29 Apr 2019
Not a Bug but the manual appears to be incorrect unless I'm using an older manual?
From the Micromite PLUS manual Ver 5.05 GUI DISPLAYBOX[code]This control does not respond to touch.[/code]
However the manual says in an earlier description that the Displaybox does responds to touch, although it's not animated with touch, and TOUCH(REF) returns the control number.
