Local Time 07:28 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite 4.5E help
goc30
Posted: 03:50pm 19 Mar 2019
hi
I want to use an expander chip MCP23017 to control some buttons and leds
for that i have to use an small pic32mx250
and micromite v4.5E
to verify all I put on Diy this 2 chips and make a little prog
'test mcp23017
'TRON
Dim vport As integer
Dim vport1 As integer
Dim vport2 As integer
Dim txport As string
SetPin 6,DIN 'INTH,irqporta
SetPin 25,dout
vport=0
vport1=-1
vport2=0
I2C open 100,1000
Dim adr_mcp1=&h20
I2C write &h20,0,5,0,0,&hff,0,&hFF 'portA=output direct, portb=input inv
Pause(100)
I2C write &h20,0,2,&h0D,&hff 'pull up intB
'I2C close
Pause(500)
Print "begin prog"
'I2C open 100,1000
I2C write &h20,0,2,&h12,&h55
Pin(25)=1
Pause(500)
I2C write &h20,0,2,&h12,&hAA
Pin(25)=0
Pause(500)
I2C write &h20,0,1,&h13
I2C read &h20,0,1,vport
'Print Hex$(vport)
If vport <> vport1 Then
vport1=vport
Print "scan rec:";Hex$(vport)
End if
'I2C close
End
but when I run, I have error
[35] End if
Error: Unexpected text
if I erase lines 32 to 35, I have no error
and it run corectly (blink is ok)
I Have read micromit's manual and I have no see that function "if/endif" is forbiden :-)
goc30
Posted: 05:04pm 19 Mar 2019
I have same bug with smaller prog without I2C functions
'test mcp23017
'TRON
SetPin 30,DIN 'INTH,irqporta
SetPin 31,dout
vport=0
vport1=-1
Pause(500)
Print "begin prog"
Pin(31)=1
Pause(500)
Pin(31)=0
Pause(500)
vport1=vport
End if
End
CircuitGizmos
Posted: 05:05pm 19 Mar 2019
Try ENDIF as one word.
If that works, then END IF as two words is broken.
goc30
Posted: 05:37pm 19 Mar 2019
  CircuitGizmos said   Try ENDIF as one word.
yes with "ENDIF" it work correctly and with "END IF" it bug!
Posted: 08:28pm 19 Mar 2019
In version 4.6 changelog:
  Quote  END IF and ELSE IF can be used as alternatives to ENDIF and ELSEIF respectively
so the change came in just after your version.
Turbo46
Posted: 09:16pm 19 Mar 2019
END IF does not work on the Maximite at the moment you must use ENDIF. It can be a bit confusing.
CircuitGizmos
Posted: 09:21pm 19 Mar 2019
Here I always thought END IF was allowed, but TassyJim is right - it appeared in 4.6.
goc30
Posted: 09:39pm 19 Mar 2019
I don't see v4.6 for pic32mx250 (or pic32mx150)
where can I download??
Turbo46
Posted: 09:53pm 19 Mar 2019
I'm guessing that you have the latest version of MMBasic for that chip. I you want to use a later version I think you need to go to the MX170.
CircuitGizmos
Posted: 10:03pm 19 Mar 2019
4.5E is the last version for the PIC32MX150F128 chip.
goc30
Posted: 02:23am 20 Mar 2019
  Turbo46 said   I'm guessing that you have the latest version of MMBasic for that chip. I you want to use a later version I think you need to go to the MX170.
I used this circuit because first I have several in my boxs and especially I wanted to test and understand the function of mcp23017 in "interrupt" mode, and it is not very simple
after when all is ok, I put the chip on my proto (with mx470)
for info, this is my final prog
'test mcp23017
dim vportA as integer 'port for output LEDS
SetPin 11,INTL,irqportb
SetPin 13,dout
vport=0
vport1=-1
vport2=0
vportA=0
I2C open 100,1000
Dim adr_mcp1=&h20
'I2C write &h20,0,11,0,0,&hff,0,&hff,0,&hff ,0,&hff,0,&hff ',0,&hFF,0,&hFF
I2C write &h20,0,3,0,0,&hff 'IODIR portA=output, portB=input
I2C write &h20,0,3,2,0,&hff 'IPOL portA=sorties directes, portB=entrees inversees
I2C write &h20,0,3,4,0,&hff 'GPINTEN portA=disable interupt on input, portB=enable int sur entrees
I2C write &h20,0,2,7,&h00 'DEFVAL portB=compare
I2C write &h20,0,2,9,&h00 'INTCON portB=
I2C write &h20,0,3,&h0a,0,&h20 'IOCON portA=no int, portB=MIRROR+ODR+INTPOL
I2C write &h20,0,3,&h0c,0,&hFF 'GPPU portA=no pullup, portB=pullup
I2C write &h20,0,3,&h0e,0,&hff 'INTF portA=no int, portB=int
I2C write &h20,0,1,&h11 'read INTCAPB
I2C read &h20,0,1,vport 'init interrupt
Pause(500)
'i2c close
Print "begin prog"
I2C write &h20,0,1,&h13 'init GPIOB
I2C read &h20,0,1,vport1
pause(100)
'I2C open 100,1000
vportA=(vportA xor 1) 'blink led
ecrportA
Pin(13)=1 'just to see if pic-prog run
Pause(500)
ecrportA
Pin(13)=0
Pause(500)
'i2c close
End
sub ecrporta
'I2C open 100,1000
I2C write &h20,0,2,&h12,vportA 'send to port A of mcp23017
I2C read &h20,0,1,vport1 'must read to valid int (why??)
'I2C close
end sub
Sub irqportb
'I2C open 100,1000
I2C read &h20,0,1,vport2
'print vport2
if vport2<>0 then
if vport2=1 then vportA = (vportA or 2)
if vport2=2 then vportA = (vportA and &hFD)
ecrporta
'Print "irq rec: ";Hex$(vport2) ';" intcap:";hex$(vport1)
end if
I2C write &h20,0,1,&h13 'READ GPIO to init int
'I2C close
Edited by goc30 2019-03-21
