Local Time 10:45 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Tera Term instruction required
Chrisk
Posted: 11:00pm 14 Mar 2019
Hi guys
Every month I need to transfer and delete 30 or so files from my maximite all with the same extension. I am currently using MM Edit but this requires me to transfer and then delete these files individually.
Could I use Tera Term and what would be the command line for a copy and then erase of all 30.
Chris K
Posted: 01:57am 15 Mar 2019
MMBasic doesn't have a bulk transfer option so you will have to write a macro for TeraTerm.
I assume (silly thing to do) that the file names are based on the date so you should be able to construct the file names in TeraTerm macro language.
Chopperp
Posted: 05:07am 15 Mar 2019
For my CMM SD files, I have a hard switch which along with software stops all SD card activity & closes files. I then remove the SD card, bung it into a laptop & do the file transfer & delete stuff.
The card then gets put back into the CMM & switch pressed again to resume SD card activity.
My main write period is every 5 mins & I'm also careful that there is no other incidental stuff being recorded.
No need to stop the CMM.
Brian
Edit, I should add that a Flag is set so that if the card is not there, no write attempts are made. Flag cleared when card re-inserted & switch pressed.Edited by Chopperp 2019-03-16
ChopperP
Turbo46
Posted: 09:52pm 17 Mar 2019
Another approach would be to write a program for the Maximite (or extend the existing one) to transfer the files via a serial link to a PC running a program in written in MMBasic for DOS. You should of course verify that the files have been saved and are correct before deleting (KILLing) the files on the Maximite - either manually or by program.
Chrisk
Posted: 01:43am 18 Mar 2019
Thanks for your replies guys.
The CMM is in a greenhouse within a weather poof case so it isn't so easy to access the SD card every month.
I had thought of transferring data via a serial link but I thought that a bulk transfer every month using MM Edit would suffice although it is a little slow and painful when you have the 30 files.
Tassy Jim - yes the file names are based on the date so it sounds like the macro would be the best way to go.
Now my question is has anyone got an example of such a macro that I could adapt?
Cheers Chris K
Turbo46
Posted: 02:42am 18 Mar 2019
I've never looked at them but this might help.
Posted: 05:26am 18 Mar 2019
You will have to play around a bit to get your file names correct but this "should" work.
send #3
n = 0
do
n = n + 1
int2str xday n
thisfile = "test"
strconcat thisfile xday
strconcat thisfile ".txt"
sendln "XMODEM SEND " #34 thisfile #34
pause 3
recfile = "C:\Users\documents\"
strconcat recfile thisfile
xmodemrecv recfile 1 1
pause 10
loop while result = 1
Timeouts take a very long time but once you have the system working, it will only time out when you run out of days in the month.
Chrisk
Posted: 10:33pm 18 Mar 2019
Thanks Jim and Bill.
Now a silly question, where would I run this program from?
The only thing I have used Tera Term for is ^C, close #1, load files and run.
Chris K
Posted: 11:19pm 18 Mar 2019
Save the script with an extension of .ttl
I put mine in the TeraTerm folder
To run it:
In TeraTerm,
Control/Macro
The TeraTerm help file has a full set of commands for TTL in it.
Chrisk
Posted: 01:15am 03 May 2019
Hi Guys
Jim, finally got around to trying out the short program however not even the first file is transferred.
I created files test1 - test6 and placed them on the micromite.
What appears on the screen after timing out is:
> XMODEM SEND "test1.txt"
Error: Remote did not respond
Any ideas?
Chris K
Posted: 01:53am 03 May 2019
  Chrisk said  Any ideas?
In Teraterm, did you do File, Transfer, XMODEM, Receive?
Posted: 03:08am 03 May 2019
Assuming he is running it with the .ttl script file, that should have happened automatically.
Can you show us the complete ttl file?
Chrisk
Posted: 05:12am 03 May 2019
Hi Guys/Jim
Thanks for your quick response.
It is virtually the same as Jim had written above except for the location where I left it as c:\Users
Here it is below.
send #3
n = 0
do
n = n + 1
int2str xday n
thisfile = "test"
pause 3
recfile = "C:\Users\"
pause 10
Posted: 06:20am 03 May 2019
try a longer pause
instead of pause 3, try pause 50 or more to start with.
Chrisk
Posted: 06:47am 03 May 2019
Hi Jim
I have tried 60 and then 80, still the same response.
I have carried out everything as you requested.
Run from Control/Macro
It runs immediately to give the first line
then after quite a few seconds up comes the error message
Error: Remote did not respond.
I am using Tera Term version 4.86 would that be a problem?
Regards Chris K
Posted: 06:55am 03 May 2019
pause is in seconds not ms as I thought.
try pause 1
If I find time, I will try and set up a test but it might be a while.
Chrisk
Posted: 07:27am 03 May 2019
Thanks Jim
No rush, I can always do it using MMedit and that is only once a month.
Chris K
Posted: 01:00am 04 May 2019
Try updating your TeraTerm.
I just tested on V4.94 and it transferred 6 consecutive files without problems.
I used an Armite H7 as the mite but all versions that allow file transfers should work the same.
> XMODEM SEND "test2.txt"
> XMODEM SEND "test3.txt"
> XMODEM SEND "test4.txt"
> XMODEM SEND "test5.txt"
> XMODEM SEND "test6.txt"
> XMODEM SEND "test7.txt"
Error: Could not find the file
After each file, a dialog box flashed briefly and on the final file (which doesn't exist), the save file dialog stayed up. I cancelled this dialog and the macro completed as it should.
send #3
n = 0
do
n = n + 1
int2str xday n
thisfile = "test"
pause 3
recfile = "C:\Users\Jim\Documents\"
pause 10
Make sure that you are saving to a location that has write permissions.
Chrisk
Posted: 07:36am 04 May 2019
Hi Jim
Yep got a new version of Tera Term and also looked at the location where I was writing the files. I suspect it was the latter that was at fault.
Played around with the pause values and found the second pause at one(1) provided the same error. However tried 5 and it did work correctly.
Sorry to have put you to so much trouble and thank you again.
Kind regards
Chris K
Chrisk
Posted: 10:18am 14 May 2019
Hi again
How does one do the equivalent of MMBasic's
INPUT ["prompt string$";] store the string as a variable and then be able to print it (to verify it is correct) in a Tera Term macro.
Chris K
