Local Time 06:18 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Time$ curiosity...
Malibu
Posted: 06:14am 09 Mar 2019
G'day All
I'm fiddling with a timing idea so I can keep track of the actual time spent doing machining on the CNC... basically, when the CNC starts, it will start the timer and once finished, the timer stops and I can see exactly how long the process has taken and bill out accordingly.
I've only started doing a few initial tests and I'm using the TIME$ function to get the time elapsed since startup... I'm just using the PRINT statement for now, like this:
print mid$(time$,1,2);"-";mid$(time$,4,2);"-";mid$(time$,7,2);" ";Time$
(Naturally, I reset the time to 0:0:0 at the start)
My question is - can I read the hours, minutes and seconds directly, or do I need to split the string and convert to a numeric value
For example, is it possible to do something like this...
print Minute$
... to only access the minutes portion of the time string?
Posted: 06:26am 09 Mar 2019
No. Not that I am aware of, anyway. You need to use MID$ as you already are, to pull-apart TIME$ into the bits you want.
Well, that is a half-truth. There is no pre-defined MINUTE$ in MMBASIC, but you most certainly could create your own MINUTE$ and reference that.
Posted: 07:11am 09 Mar 2019
  Quote   starttime$ = TIME$
PRINT "Starting at "+starttime$
PAUSE 10000
'do stuff
endtime$ =
TIME$
PRINT "Stopping at "+endtime$
PRINT "timetaken = "+STR$(secsX(endtime$)-secsX(starttime$))+ " sec"
PRINT " which is = "TimeX$(secsX(endtime$)-secsX(starttime$))
END
FUNCTION secsX(dt$) AS INTEGER
' given date as "hh:mm:ss"
' returns time in seconds
LOCAL INTEGER hh,mm,ss
hh=
VAL(MID$(dt$,1,2))
mm=
VAL(MID$(dt$,4,2))
ss=
VAL(MID$(dt$,7,2))
secsX=hh*
60*60+mm*60+ss
END FUNCTION
FUNCTION TimeX$(u AS INTEGER)
' given seconds returns time formatted
LOCAL hh,mm,ss
hh=
INT(u/3600)
mm=
INT((u MOD 3600)/60)
ss=(u
MOD 3600) MOD 60
TimeX$ =
STR$(hh,2,0,"0")+":"+STR$(mm,2,0,"0")+":"+STR$(ss,2,0,"0")
END FUNCTION
Malibu
Posted: 07:15am 09 Mar 2019
Thanks Grogs, it's all good
It doesn't take a whole lot of extra code (or time) to convert the string, so I'm happy enough to do it that way... (it was just a curious question that I thought I may have missed the answer to reading the manual)
I'll need to extract each value (disregarding the seconds), convert to a value and tally-up that for total minutes elapsed.
For example - 01:30:00 on the time$ function would end up being 90 minutes - calculated to decimal works out to 1.5 Hours.
(I need to calculate by decimal time intervals)
I'll post the code once I sort it all out in case it helps someone else in the future
For now... it's dinner time!
Posted: 02:22pm 09 Mar 2019
you can also just use the millisecond timer:
Start = Timer
' do the stuff in here that takes time
Elapsed = (Timer-Start)/1000
Print Elapsed " seconds"
rob :-)
Malibu
Posted: 10:03pm 09 Mar 2019
Thanks everyone... all good answers and suggestions
Here's this morning's effort which is good enough for what I'm trying to do
OPTION EXPLICIT
DIM True=1, False=0
DIM ShowNewTime = False
DIM ElapsedTime AS FLOAT
TIME$="1:59:30" 'Initialise the clock for testing (in use, set to 0:0:0)
SETTICK 1000, UpdateDisplay 'Interval for showing the time
DO
IF ShowNewTime = True THEN GOSUB ShowTime
LOOP
ShowTime:
ElapsedTime=VAL(STR$(((VAL(MID$(TIME$,1,2))*3600)+(VAL(MID$(TIME$,4,2))*60)+VAL(MID$(TIME$,7,2)))/3600,0,4))
PRINT ElapsedTime;" | ";Time$ 'print the decimal time and the clock for debug
ShowNewTime = False
RETURN
SUB UpdateDisplay
ShowNewTime = True
END SUB
I don't actually need to know the start time because it's always going to be reset to "00:00:00" when the spindle starts.
Posted: 12:58pm 10 Mar 2019
deleted...Edited by MicroBlocks 2019-03-11
goc30
Posted: 01:00pm 10 Mar 2019
Hi Jim
why in function TimeX, did you use
hh= INT(u/3600)
and not
hh= u\3600
I have tested speed dif between 2 lines.
in loop "for i=1 to 1000" I win....
1 ms, yesssss!!!
Posted: 08:22pm 10 Mar 2019
  goc30 said   Hi Jim
hh= INT(u/3600)
and not
hh= u\3600
1 ms, yesssss!!!
Left over from the days before we had INTEGERs
Showing my age.
