Forum Index : Microcontroller and PC projects : BLIT on Armmite H7 - flashing
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2287 |
I've had a search but came up empty. I'm using blit to read / restore an image on "part" of the and 8" display on an ArmMite H7. Everything works as expected but of course I get flashing of the updated triangle pointer positions using blit write, not all the time, I can get 4 or 5 blit write updates restoring the previous background with no flashing before I get 3 or 4 updates with flashes and so on repeating. I assume it's to do with not writing to the display at the correct scan time, so my Questions are: 1: Am I on the right track? 2: Is there a way to detect the scan position on the H7? I can't use refresh as the 8" screen in buffer mode only leaves 96K of ram for blitz copy. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
There is a function that I hadn't previously implemented to help with this. getscanline() This return the current line that is being written to by the display controller. By a process of trial and error you can use this to delay writes until the display cursor is "out-of-the-way" Included in this version (very very limited testing) 2019-02-19_195727_Armmite1.3.zip example use: i=getscanline() do while i>400 or i<= mm.fontheight i=getscanline() loop text 0,0,TIME$ This is also implemented in the MM+ and MMX but doesn't seem to appear in the MM+ manual |
Once again, thank you for the quick reply, exactly what I wanted. Using getscanline() I now have "blit write" running with no flashing, it took a while to get the sweet spot though. I now have a beautiful big clock running on half the 8" screen, now I can add lots of alarm times, spoken messages/music/chimes, calendar reminders and more. Auto backlight makes it great at night, with an 8" screen you can read the clock from across the room at a glance. Thanks again. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
