Forum Index : Microcontroller and PC projects : Scrolling text
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
Is it possible to have scrolling text on an SSD1963 display? |
Need more specific question, left/right? , up/down?, overlaying background? platform? |
Sorry I should have been more specific Right to Left no picture just a background colour |
I assume Pi-cromite? FONT 4 option autorefresh off a$="Hello world, this is a test of right to left scrolling. " do for i=0 to -mm.fontwidth*len(a$) step -1 text i,0,a$ text i+mm.fontwidth*len(a$),0,a$ refresh next i loop |
Thanks Peter Would you mind if I ask what the -mm and +mm means? I'm trying to see if I can get scrolling text on a certain position of the screen maybe in a box if thats possible I'd like to put a simple weather description and a few other things scrolling underneath the date on the clock |
mm.fontwidth is the width (in pixels) of a character in the font. The code is moving the position of the displayed text one pixel at a time to the left. "+" and "-" are the normal addition and subtraction operators. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thanks I guess there's no way to keep both the clock ticking and the text scrolling at the same time>? I've tried every combination I can think of that might work I've got the clock working perfectly, and the scrolling perfectly but cannot get both working together 2019-02-17_043314_picture.zip [code] '***Thanks to Matherp for his excellent clock code*** option explicit option default none dim integer buff(480*460*3/8-1) dim integer nt=4 'Number of triangles being updated dim integer xx0(nt-1),yy0(nt-1),xx1(nt-1),yy1(nt-1),xx2(nt-1),yy2(nt-1),tcol(nt-1),secs,mins,hours,first=1 dim integer oldsecs,i dim a$ cls RGB(black) load image "3.bmp",0,0 circle 240,240,238,2,1,RGB(RED) blit read #1,0,0,480,480 FONT 4 option autorefresh off a$="Hello world, this is a test of right to left scrolling. " do secs=val(right$(time$,2)) mins=val(mid$(time$,4,2)) hours=val(left$(time$,2)) mod 12 if secs <> oldsecs then hands(secs,mins,hours,(MM.HRES\2-MM.HRES\12),MM.Hres\2, MM.HRES\2) for i=0 to -mm.fontwidth*len(a$) step -2 text i,650,a$ text i+mm.fontwidth*len(a$),650,a$ refresh next i Text 100,540, day$(now) , LB, 4, 2, RGB(white),RGB(black) 'Day Text 70,600, date$ , LB, 4, 2, RGB(white),RGB(black) end if oldsecs = secs loop end Sub hands(seconds As integer, minutes as integer, hours as integer, size as integer, x as integer, y as integer) Local integer x1,y1,x2,y2,x0,y0,i local float angle=seconds*6 rotatetriangle(2,RGB(RED),angle,x,y,-3,50,3,50,-3,-size) 'make up the second hand with two triangles rotatetriangle(3,RGB(RED),angle,x,y,3,-size,3,50,-3,-size) angle=minutes*6 + seconds/10 rotatetriangle(0,RGB(green),angle,x,y,-size/20,0,size/20,0,0,-size*0.9) angle=hours*30 + minutes/2 rotatetriangle(1,RGB(green),angle,x,y,-size/20,0,size/20,0,0,-size*0.75) blit write #1,0,0 triangle xx0(), yy0(), xx1(), yy1(), xx2(), yy2()) ,tcol() ,tcol() Circle x,y, size\16, 0, , rgb(red), rgb(red)) Circle x,y, size\20, 0, , 0, 0 Circle x,y, size\24, 0, , RGB(gray), RGB(gray) refresh End Sub sub rotatetriangle(n as integer, col as integer, angle as float, x as integer, y as integer, x0 as integer, y0 as integer, x1 as integer, y1 as integer, x2 as integer, y2 as integer) local float sine=sin(rad(angle)),cosine=cos(rad(angle)) local integer x0a,y0a,x1a,y1a,x2a,y2a x0a= x0*cosine - y0 * sine + x y0a= y0*cosine + x0 * sine + y x1a= x1*cosine - y1 * sine + x y1a= y1*cosine + x1 * sine + y x2a= x2*cosine - y2 * sine + x y2a= y2*cosine + x2 * sine + y xx0(n)=x0a yy0(n)=y0a xx1(n)=x1a yy1(n)=y1a xx2(n)=x2a yy2(n)=y2a tcol(n)=col end sub [/code] |
For a one-second per pixel shift, try this (if I've understood): [code] i = 0 do secs=val(right$(time$,2)) mins=val(mid$(time$,4,2)) hours=val(left$(time$,2)) mod 12 if secs <> oldsecs then hands(secs,mins,hours,(MM.HRES\2-MM.HRES\12),MM.Hres\2, MM.HRES\2) text i,650,a$ text i+mm.fontwidth*len(a$),650,a$ refresh i = i - 2 if i < -mm.fontwidth*len(a$) then : i = 0 : endif Text 100,540, day$(now) , LB, 4, 2, RGB(white),RGB(black) 'Day Text 70,600, date$ , LB, 4, 2, RGB(white),RGB(black) end if oldsecs = secs loop [/code] PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thank you, it was going a bit slow so I changed it slightly and now it works great apart from a pause for a moment as the second hand moves. I really with the MM could do 2 things at the same time then the second hand could move while the text was still scrolling instead of pausing to move the tick You can see what I mean here - YouTube Link [code]FONT 4 a$="Hello world, this is a test of right to left scrolling. " i = 0 do secs=val(right$(time$,2)) mins=val(mid$(time$,4,2)) hours=val(left$(time$,2)) mod 12 text i,650,a$ text i+mm.fontwidth*len(a$),650,a$ refresh i = i - 2 if i < -mm.fontwidth*len(a$) then : i = 0 : endif if secs <> oldsecs then hands(secs,mins,hours,(MM.HRES\2-MM.HRES\12),MM.Hres\2, MM.HRES\2) Text 100,540, day$(now) , LB, 4, 2, RGB(white),RGB(black) 'Day Text 70,600, date$ , LB, 4, 2, RGB(white),RGB(black) end if oldsecs = secs loop[/code] |
Peter if you spot this post is there a way to limit the width of the scroll? I've figured out where to start the scroll from but it always then scrolls across the full width of the screen An example of what I'd like is on an SSD1963 scroll from 50 to 350 where the width is 800 if that makes sense |
BLIT READ the part of the screen after column 350. Write the text full width. Then BLIT WRITE the original screen contents back. Do this with AUTOREFRESH OFF and only refresh once the BLIT WRITE has completed |
I can't get this to work, I can get it so it works but it still writes to the full width of the screen I cannot get the word drizzle to scroll inbetween the word Summary and the red line on the right no matter what I try it always starts ok, but then scrolls the whole width [code] '***Thanks to Matherp for his help with the hands*** cls RGB(white) option explicit option default none dim integer buff(480*480*3/8-1) dim integer nt=4 'Number of triangles being updated dim integer xx0(nt-1),yy0(nt-1),xx1(nt-1),yy1(nt-1),xx2(nt-1),yy2(nt-1),tcol(nt-1),secs,mins,hours,first=1 dim integer oldsecs,i DIM STRING q$=chr$(34) dim x$,z$,Temp$,Wind$,prob$,type$,summary$ dim integer val1 Dim INTEGER a(10000) SetTick 900000,weather,1 'every 15 minutes load image "4.bmp",0,0 circle 240,240,238,3,1,RGB(RED) blit read #1,0,0,480,480 blit write #2,350,710 option autorefresh off FONT 4,2 i = 0 secs=val(right$(time$,2)) mins=val(mid$(time$,4,2)) hours=val(left$(time$,2)) mod 12 Text 100,530, day$(now) , LB, 4, 2, RGB(BLACK),RGB(WHITE) 'Day Text 70,590, date$ , LB, 4, 2, RGB(BLACK),RGB(WHITE) 'Date weather do secs=val(right$(time$,2)) mins=val(mid$(time$,4,2)) hours=val(left$(time$,2)) mod 12 if secs <> oldsecs then hands(secs,mins,hours,(MM.HRES\2-MM.HRES\12),MM.Hres\2, MM.HRES\2) end if mins = 0 and secs = 0 elseif mins = 15 and secs = 0 elseif mins = 30 and secs = 0 elseif mins = 45 and secs = 0 then weather pause 800 end if if time$ = "00:00:00" then Text 100,530, " ") , LB, 4, 2, RGB(BLACK),RGB(WHITE) 'Clear Day Text 100,530, day$(now) , LB, 4, 2, RGB(BLACK),RGB(WHITE) 'Day Text 70,590, " ", LB, 4, 2, RGB(BLACK),RGB(WHITE) 'Clear Date Text 70,590, date$ , LB, 4, 2, RGB(BLACK),RGB(WHITE) 'Date pause 950 end if BOX 2, 620, 476, 175, 3, RGB(red) text i,650,summary$ text i+mm.fontwidth*len(z$),720,summary$ refresh i = i - 2 if i < -mm.fontwidth*len(summary$) then : i = 0 : endif blit write #2,350,710 refresh oldsecs = secs loop end sub weather system "wget -q -O- "+q$+"https://api.darksky.net/forecast/458113cd1162af4b1f0677d08822fbaf/53.440120,-2.106181?units=uk2&exclude=flags,aler ts,minutely"+q$,a() pause 700 on error IGNORE Temp$ = JSON$(a(),"currently.temperature")+"`C " Wind$ = JSON$(a(),"currently.windspeed")+"MPH " prob$ = JSON$(a(),"hourly.data[0].precipProbability") type$ = JSON$(a(),"hourly.data[0].precipType") summary$ = JSON$(a(),"currently.summary") Text 60,660, " ",LB, 4, 1, RGB(BLACK),RGB(WHITE) Text 60,660, "Temperature "+ Temp$ , LB, 4, 1, RGB(BLACK),RGB(WHITE) Text 60,700, " ",LB, 4, 1, RGB(BLACK),RGB(WHITE) Text 60,700, "Windspeed "+ Wind$, LB, 4, 1, RGB(BLACK),RGB(WHITE) Text 60,740, " ",LB, 4, 1, RGB(BLACK),RGB(WHITE) Text 60,740, "Summary "'+ summary$ , LB, 4, 1, RGB(BLACK),RGB(WHITE) val1 = val(prob$) val1 = val1 * 100 print val1, "Val1" if val1 >= 1 then print val1 Text 60,780, " ",LB, 4, 1, RGB(BLACK),RGB(WHITE) Text 60,780, STR$(val1)+ "% chance of "+type$, LB, 4, 1, RGB(BLACK),RGB(WHITE) end if print STR$(val1), "Val" print Wind$ end sub Sub hands(seconds As integer, minutes as integer, hours as integer, size as integer, x as integer, y as integer) Local integer x1,y1,x2,y2,x0,y0,i local float angle=seconds*6 rotatetriangle(2,RGB(RED),angle,x,y,-3,50,3,50,-3,-size) 'make up the second hand with two triangles rotatetriangle(3,RGB(RED),angle,x,y,3,-size,3,50,-3,-size) angle=minutes*6 + seconds/10 rotatetriangle(0,RGB(black),angle,x,y,-size/20,0,size/20,0,0,-size*1.04) ' Minute hand angle=hours*30 + minutes/2 rotatetriangle(1,RGB(black),angle,x,y,-size/20,0,size/20,0,0,-size*0.78) ' Hour hand blit write #1,0,0 triangle xx0(), yy0(), xx1(), yy1(), xx2(), yy2()) ,tcol() ,tcol() Circle x,y, size\16, 0, , rgb(red), rgb(red)) Circle x,y, size\20, 0, , 0, 0 Circle x,y, size\24, 0, , RGB(red), RGB(red) refresh End Sub sub rotatetriangle(n as integer, col as integer, angle as float, x as integer, y as integer, x0 as integer, y0 as integer, x1 as integer, y1 as integer, x2 as integer, y2 as integer) local float sine=sin(rad(angle)),cosine=cos(rad(angle)) local integer x0a,y0a,x1a,y1a,x2a,y2a x0a= x0*cosine - y0 * sine + x y0a= y0*cosine + x0 * sine + y x1a= x1*cosine - y1 * sine + x y1a= y1*cosine + x1 * sine + y x2a= x2*cosine - y2 * sine + x y2a= y2*cosine + x2 * sine + y xx0(n)=x0a yy0(n)=y0a xx1(n)=x1a yy1(n)=y1a xx2(n)=x2a yy2(n)=y2a tcol(n)=col end sub[/code] |
