Local Time 04:08 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Finding data sheet for power supply
plover
Posted: 07:42am 14 Feb 2019
Starting to clear a path through a lot of stuff under the house when I had to get to the hot water cylinder under the house. Controller broken down. Wire in temp controller. Then unrelated to hot water cylinder found an industrial board having what I believe is an Intronics Inc. power module on a pcb of some size.:
Intronics
SM 300/5-150/12
I believe it is a 240V (there is a fuse 3AG 313 littlefuse, 250V) driven by 240V having 5V and 12V DC out.
Have searched the internet but the Intronics Inc I knew back in the last century seems gone.
Anybody by chance having a power catalogue from them with the SM series?
twofingers
Posted: 11:16am 14 Feb 2019
  plover said  ... Intronics
SM 300/5-150/12
Hi plover,
I don't have a power catalogue and I know nothing specific about the SM 300/5-150/12.
But I found this https://core.ac.uk/download/pdf/51243018.pdf.
  Quote  Alimentation stabilisée ±12 V, 150 mA
(modèle SM 300/5 150/12 de Intronics).
I don't know if that helps a little ...
Michael
plover
Posted: 12:27pm 14 Feb 2019
twofingers
Thank you, it helps. Canada mains power listed as 120V and I could not determine from the pdf if they also use 240V AC. The current large enough to drive a number of OP amps.
Posted: 12:34pm 14 Feb 2019
Is there a reason you want to replace that specific device? Space/tidyness etc?
5V & 12V PSU not hard to come by if you are forced to home-brew.
