Forum Index : Microcontroller and PC projects : TEMPR=542C....
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10081 |
This one is another one I can't work out. An 18B20 sensor stuck onto a heater plate, 50% of the time, the result returned is correct - about 37'C. The other 50% of the time, the result is ALWAYS 542'C. I know that cannot be correct, as I doubt I would be alive at 542'C.... Can anyone suggest why that should be? Relevant code is: Smoke makes things work. When the smoke gets out, it stops! |
| JohnL Senior Member Joined: 10/01/2014 Location: SeychellesPosts: 128 |
Deleted |
| Solar Mike Guru Joined: 08/02/2015 Location: New ZealandPosts: 1255 |
Hi Grogster, put your scope between 0v and the data line, at the sensor; you may have noise on the wire stuffing up the readings. I had one of these play up awhile ago whenever a 230 vac fan turned on, ended up being induced mains noise, fixed with ferrite chokes. Cheers Mike |
I've seen occasional errors on mine when the 5V supply is bad or there's interference. But then again mine are on long strings, one exceeding 30m. 542 is a weird result to get though, as it can't be derived from the binary output of the things. 2^6 is the most significant bit, which would allow a maximum reading on 127°C. I do have a vague recollection of some firmware issue relating to DS18B20's, but think that may have been on ARMs or something. |
Cool, thanks for the suggestions. @ JohnL: Deleted. Now you have made me curious as to what you posted. Do tell. ![]() Smoke makes things work. When the smoke gets out, it stops! |
| GoodToGo! Senior Member Joined: 23/04/2017 Location: AustraliaPosts: 188 |
I wonder if it's a calculation error? 542 is 0000 0010 0001 1110 in binary. According to the datasheet, a valid DS18B20 12 bit reading of that binary number equates to 33.875 degrees. Food for thought? Cheers! GTG! ...... Don't worry mate, it'll be GoodToGo! |
Definitely food for thought but I can't see how it's happening. The relevant bit of code in the firmware (V5.3) is fret = (float)((short)(((unsigned short)b2 << 8) | (unsigned short)b1)) / 16.0; Something in the timing that causes a shift of 4 bits to the left? Jim VK7JH MMedit |
