Local Time 04:08 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC32PROG error....
Posted: 05:55am 04 Feb 2019
Hi all.
This is an odd error, and I have no idea what it means. Can someone tell me what it is trying to tell me?
Programmer for Microchip PIC32 microcontrollers, Version 2.0.193
Copyright: (C) 2011-2015 Serge Vakulenko
(ascii ICSP coded by Robert Rozee)
Adapter: . OK1 OK2 - ascii ICSP v1N
Processor: MX170F256D
Flash memory: 256 kbytes
Boot memory: 3 kbytes
Data: 258392 bytes
Erase: (20mS) done
Loading PE: 1 2 3 4 (LDR) 5 6 7a (PE) 7b 8 v0301
Program flash: ................................................
total TDI/TMS pairs sent = 32569 pairs
total TDO bits received = 3424 bits
total ascii codes sent = 10756
total ascii codes recv = 1186
maximum continuous write = 452 chars
O/S serial writes = 1104
O/S serial reads (data) = 110
O/S serial reads (sync) = 10
XferFastData count = 461
10mS delays (E/X/R) = 2/0/0
elapsed programming time = 0m 01s
failed to program row at 1d000000, reply = 00000002
It obviously starts to program fine, then falls over. One would be thinking faulty PIC32, but it was a brand new one, so I don't think it could be that, could it?
I wear full anti-static straps, grounded irons etc,so it can't have been statically damaged.
Posted: 08:15am 04 Feb 2019
Looks like it failed almost immediately.
You may need to say what board etc the CPU is in and what else is involved. Those items are suspects.
JohnEdited by JohnS 2019-02-05
Posted: 01:01pm 04 Feb 2019
1d000000 is the very beginning of flash memory, while error 2 is simply "command unsuccessfully processed". the error is being generated by the PE that runs on the target processor while programming is happening.
i've seen this exact same address/error before - quite a long time ago, and i remember it being because of something quite simple. it could have been Vcc not solid enough or too low, or a missing Vcap. essentially the mx170 having enough juice to run a program (the PE), but not enough oomph to complete a flash write.
the 20ms erase time is also suspiciously low, from past experience i'd normally expect to see around 80ms or so.
are you using a 1455 or a nano as the programmer? is there any other circuitry on the board containing the mx170 that is drawing power? are all Vcc and ground pins connected?
rob :-)
addendum: "ascii ICSP v1N", it must be a 1455.
Edited by robert.rozee 2019-02-05
Posted: 08:59pm 04 Feb 2019
It is a 1455.
I've never run into this problem before, so I'm a little stumped. The 1455 always just works.
The board is a special board I did for a client - it is not a public design, but all the standard design requirements were met. The board failed(user error), and when I got it back, there were two burn-through holes in the PIC32, so I knew that was toast. I removed it and replaced it after first checking all the voltages etc. I have a feeling that whatever happened to the board has also damaged something else on the same board. I will remove this 'Suspect' processor, and build a brand-new board and put this processor on it and see if I can program it in that.
I will let the thread know if that succeeds.
Posted: 09:26pm 04 Feb 2019
Hi Grogs,
OK the original Pic170 is obviously Popped. So it was hit by some spike...
I would suspect the 1455 is dead as well.
obviously, I assume , you have checked the voltage is correct and smooth.
Kind Regards,
MickEdited by bigmik 2019-02-06
Posted: 10:09pm 04 Feb 2019
1455 is seperate from the board, as a programmer, so it was not on the board when it was killed, so it is fine. All voltages checked out when I tested the board BEFORE I fitted the new PIC32 chip. 3v3 rail was 3.2v - slightly low, but I still think that is close enough. Another new board measures 3.2v on that regulator too. (1117-3.3)
I don't think it is worth the effort of playing with this one anymore, as just about everything else on the board is an unknown at this point.
I have started building a new one.
