Local Time 04:07 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ads1115 library.
crez
Posted: 04:41am 03 Feb 2019
I recall reading that one existed for the micromite for this A/D chip. Can someone please point me to it.
David
Quazee137
Posted: 09:12am 03 Feb 2019
I do recall something but don't remember as it was awhile back.
Here is a test setup I did with the ADS1115. The jest of it was from
some python code from Adafruit.
Option explicit
Dim float adc01,adc23,adc0,adc1,adc2,adc3,getvolts,tmp,ofs=-2.67
Dim startime$
RTC gettime
RTC SETREG &h07,&h92
startime$=Time$
Dim fs=2,p=0
I2C open 100,5000
Box 0, 0, MM.HRes-1, MM.VRes-1, 8, , RGB(yellow)
PWM 2,1000,50
'SetTick 3600000,settime,1 'update time from RTC hourly
SetTick 750,ADC,4 'periodical reading
clr
locate 5,1
Print startime$;" ";Time$;" "
Print "Volts A01 is "; adc01
Print "Volts A23 is "; adc23
Print "----------------------"
Print "Volts A0 is "; adc0
Print ((adc0-.4)/0.2925);"pH "
Print
Print "Volts A1 is "; adc1
Print (adc1-2.7315)*100
Print
Print "Volts A2 is "; adc2
Print
Print "Temp ";Str$((adc2-2.7315)*100,0,3);"C "
Print "Temp ";Str$((adc2-2.7315)*100*(9/5)+32,0,3);"F "
'Print Str$((adc2-2.7315)*100*(9/5)+32+ofs,0,4);" F "
Print "Volts A3 is "; adc3
Print "--------------------"
tmp=TEMPR(16)
Print "The temp ";Str$(tmp,0,3);" C ",Str$(tmp*1.8+32,0,3);" F "
Text MM.HRes/2,30,Date$+" "+Time$,cm,1,fs,RGB(red),RGB(yellow)
Text 10,40,"A01 is "+Str$(adc01,2,5),,1,fs,RGB(blue),RGB(yellow)
Text 10,65,"A23 is "+Str$(adc23,2,5),,1,fs,RGB(blue),RGB(yellow)
Text 10,90,"A0 is "+Str$(adc0,2,5),,1,fs,RGB(blue),RGB(yellow)
Text 10,115,"A1 is "+Str$(adc1,2,5),,1,fs,RGB(blue),RGB(yellow)
Text 10,140,"A2 is "+Str$(adc2,2,5),,1,fs,RGB(blue),RGB(yellow)
Text 10,165,"A3 is "+Str$(adc3,2,5),,1,fs,RGB(blue),RGB(yellow)
Text 10,190,"Tmp is "+Str$(tmp*1.8+32),,1,fs,RGB(blue),RGB(yellow)
Sub ADC ' ADC reading
Local cfreg,cnv,cfhi,cflo
cfreg = &h01: cnv =&h00 ' rate 128 sps no comp operations
cfhi = &h83 : cflo= &h81 'reading Dif Ain0 , Ain1,FS= +/- 4.096 , 128 sps
I2C write &H48,0,3,cfreg,cfhi,cflo 'adr 48 point to config reg
I2C write &h48,0,1,cnv ' adr 48 point to conversion reg
getadc
adc01 = getvolts
cfhi = &hB3 : cflo= &h81 ' reading Dif Ain2 , Ain3,FS= +/- 4.096 , 128 sps
getadc
adc23 = getvolts
cfhi = &hC3 : cflo= &h81 ' reading single Ain0,FS= +/- 4.096 , 128 sps
getadc
adc0 = getvolts
cfhi = &hD3 : cflo= &h81 ' reading single Ain1,FS= +/- 4.096 , 128 sps
getadc
adc1 = getvolts
cfhi = &hE3 : cflo= &h81 ' reading single Ain2,FS= +/- 4.096 , 128 sps
getadc
adc2 = getvolts
cfhi = &hf3 : cflo= &h81 ' reading single Ain1,FS= +/- 4.096 , 128 sps
getadc
adc3 = getvolts
Sub getadc
Local adcv
Local integer adcrd(2) 'to receive 2 bytes
Pause 100
I2C read &h48,0,2,adcrd()
adcv= (adcrd(0)<<8) Or adcrd(1)
If adcv > &H7fff Then adcv = adcv - &HFFFF
getvolts = adcv *(4.096/32768)
Sub settime
RTC gettime
Pause 50
Sub clr
Print Chr$(27)+"[f" : Print Chr$(27)+"[2J"
Sub locate x,y
Print Chr$(27)+"["+Str$(X)+";"+Str$(Y)+"f";
crez
Posted: 10:59am 03 Feb 2019
Thanks very much for that. There are enough comments to make my job pretty easy.
