Local Time 03:05 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Grey Cells need checking
OA47
Posted: 10:47pm 31 Jan 2019
I have a sub routine that is not working as expected and I was wondering if someone could point out my error.
I have a star network of LoRa units attached to a MM and the controlling radio broadcasts a time stamp regularly to keep the remote unit clocks up to date for reporting purposes. The time stamp is 10 characters in length and is made up of DDMMYYHHMM. The remote units react to any string ending in a CR but occasionally I will get a unit that reboots and as the console port is connected to the radio RS232 it broadcasts the reboot characters. This should not be a problem except the other units are rebooting in sympathy as they are seeing some of this code as an incorrect date format and rebooting on Error: Invalid date (the string sent out is "__________" and the code is trying to set the date as "__/__/__". I thought that my code would exclude this sort of string.
Sub SetClock
' N$ Should look like "2512191645"
If Val(Mid$(N$,5,2)) > 18 Then If Val(Right$(N$,4)) < 2400 Then
D$=Left$(N$,2)+"/"+Mid$(N$,3,2)+"/"+Mid$(N$,5,2)
Print " Date$ set to "; D$
Date$=D$
T$=Mid$(N$,7,2)+":"+Right$(N$,2)+":30"
Print " Time$ set to "; T$
Time$=T$
Else
Print Err$(5)
End If
Help
OA47
disco4now
Posted: 11:09pm 31 Jan 2019
I am not sure this is a valid structure for the IF THEN on a single line.
What about
If Val(Mid$(N$,5,2)) > 18 AND Val(Right$(N$,4)) < 2400 Then
An initial test that its length is 10 would also help filter out non dates
If (len(N$)=10) AND (Val(Mid$(N$,5,2)) > 18) AND (Val(Right$(N$,4)) < 2400) Then
F4 H7FotSF4xGT
OA47
Posted: 11:31pm 31 Jan 2019
Thanks disco4now,
  Quote  An initial test that its length is 10 would also help filter out non dates
The string is tested to be 10 chars long before it proceeds to the sub.
Changed the code from a "Then If " to an "And" and I haven't got the Invalid date error but I also haven't seen the Err$(5) printed.
OA47
Posted: 12:01am 01 Feb 2019
  Quote   N$ = "2512191645"
setclock
n$ =
"__________"
setclock
SUB SetClock
IF VAL(MID$(N$,5,2)) > 18 THEN
IF VAL(RIGHT$(N$,4)) < 2400 THEN
D$=
LEFT$(N$,2)+"/"+MID$(N$,3,2)+"/"+MID$(N$,5,2)
PRINT " Date$ set to "; D$
DATE$=D$
T$=
MID$(N$,7,2)+":"+RIGHT$(N$,2)+":30"
PRINT " Time$ set to "; T$
TIME$=T$
ENDIF
ELSE
PRINT Err$(5)
END IF
END SUB
Combining single line and multiline IFs is not a good idea
Date$ set to 25/12/19
Time$ set to 16:45:30
[20] Print Err$(5)
Error: ERR is not declared
OA47
Posted: 12:24am 01 Feb 2019
Thanks Jim. I thought I might give the string another qualifier as well and see how that goes.
Sub SetClock
If Val(Mid$(N$,3,2)) < 13 Then
Date$=D$
Time$=T$
End If
End If
Else
Print Err$(5)
End If
OA47
Posted: 12:35am 01 Feb 2019
In that case you can combine
into
If Val(Mid$(N$,5,2)) > 18 and Val(Right$(N$,4)) < 2400 Then
Posted: 10:30am 01 Feb 2019
I strongly recommend putting brackets around the expressions either side of the AND to ensure the 'correct parts' are AND'd:
If (Val(Mid$(N$,5,2)) > 18) AND (Val(Right$(N$,4)) < 2400) Then
Also makes it clearer to read when tracking down errors Edited by WhiteWizzard 2019-02-02
Posted: 11:08am 01 Feb 2019
as an aside (a bit) here, I have two functions that use regular expressions to validate the "look and feel" of date and time strings and then the actual values of them here:
http://www.fruitoftheshed.com/MMBasic.IsDate-and-IsTime-functions-VB-Work-A-Like.ashx
the functions simply return a true(1) or false(0) if the input string is or isn't a date or time.
I use this all over my code where I set the date & time remotely - One product I have uses a star network of HC-12s and slave nodes get a periodic broadcast timecheck just like yours. The slaves pick out the time and date then use these two functions before setting their own internal clocks to prevent errors from garbage.Edited by CaptainBoing 2019-02-02
