Local Time 04:06 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Photo Viewer
detonat3
Posted: 05:48am 27 Jan 2019
Hi all,
I'm just wondering if anyone can help me, I am only new to programming and I'm trying to create a photo viewer using a Micromite Plus LCD Backpack.
Is there already a thread on this or is someone able to direct me to somewhere I can find the code to do this?
Edited by detonat3 2019-01-28
Posted: 05:58am 27 Jan 2019
Hello and welcome.
If you happen to use the Micromite Plus, the MicroMite Extreme(MMX), or the ARM-mite, most of the work is done for you.
See the LOAD IMAGE command, page 54 of the advanced manual for the MM+ series of chips. The image must be a BMP(bitmap), but it can be a true-colour 24-bit BMP file, you just need to have the image on the SD card.
Done.
detonat3
Posted: 07:47am 27 Jan 2019
  Grogster said   Hello and welcome.
Done.
Thanks Grogster, I'm almost there now but I'm getting a syntax error. Is there a typo in the manual? Thanks
Posted: 02:29pm 27 Jan 2019
There is no typo. The command is:
LOAD IMAGE filename$
Where filename$ is a string expression, variable or constant. If you are using a string constant for the file name it should be surrounded by double quotes. For example:
LOAD IMAGE "TIGER.BMP"
I bet that is your problem.
You should post your code, then we could spot what you are doing wrong.
detonat3
Posted: 10:02pm 27 Jan 2019
OK at one point in the manual it shows LOAD IMAGE file$ [, x, y] I was trying to include the x and y section but it turns out I don't need it.
Posted: 10:28pm 27 Jan 2019
Yes, that does catch a few newcomers. The square brackets indicate an optional parameter for any MMBASIC command, so if you don't need to specify them, don't.
detonat3
Posted: 11:55pm 27 Jan 2019
Great, thanks for the help
subalib
Posted: 05:19am 07 Feb 2019
iEdited by subalib 2019-02-09
