Local Time 01:03 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with Graphics
OA47
Posted: 02:11am 06 Jan 2019
@ Geoff : Wondering if you would consider adding ARC to the basic drawing commands (Part circle)
In the meantime I am having trouble drawing a right half circle 60 pixels wide on a micromite. To draw the first quadrant I tried:
For X=1 To 60
Pixel X,60-(60^2-X^2)^-2
Next X
But because the values in the equation over run the 32bit calculator I cannot use this equation.
Any thoughts?
Found the error. SQRT should be represented ^0.5
Edited by OA47 2019-01-07
panky
Posted: 02:49am 06 Jan 2019
OA47,
Try this code - slow, especially for thick arcs.
' Routine to draw an arc segment of a circle
' - based on segment code from Peter Mather.
' test parameters and test code
x% =400
y% =200
outsize% = 100
startradial% = 225
endradial% = 135
col% = 65534
insize% = 50
cls
for outsize% = 100 to 102
insize% = outsize%
arc x%,y%,outsize%,startradial%,endradial%,col%,insize%
next outsize%
end
' End of test code
' Parameters are:
' x-coordinate of centre of arc circle
' y-coordinate of centre of arc circle
' outsize or radius of circle
' start radial of arc to be drawn (0-360 degrees)
' NB: 0 degrees is at North (top)
' end radial of arc to be drawn (0-360 degrees)
' colour to draw arc
' inner radius for drawing radial lines (thickness or arc), leave blank or set to zero if not required
' NB arc is composed of radial lines so if insize is more than about
' 5 different from outsize, the arc will not be smooth. If a thick, smooth arc
' is required, draw multiple arcs with differing radii
Sub arc(x%, y%, outsize%, startradial%, endradial%, col%, insize%)
Local integer i%, x1%, x2%, y1%, y2%, sr%, er%
Local stepsize% = 1
If startradial% < endradial% Then
sr%=startradial%
er%=endradial%
' now draw arc
For i%=sr% To er% Step stepsize%
x2%=Sin(Rad(i%))*outsize% + x%
y2%=-Cos(Rad(i%))*outsize% + y%
x1%=Sin(Rad(i%-stepsize%))*insize% + x%
y1%=-Cos(Rad(i%-stepsize%))*insize% + y%
Line x1%,y1%,x2%,y2%,,col%
Next i%
Else ' draw 2 part arc via zero
er%=360
sr%=startradial%
' now draw arc from sr to 0
Next i%
er%=endradial%
sr%=0
' now draw arc from 0 to er
Next i%
AussieWombat
Posted: 02:55am 06 Jan 2019
Isn't it just cosine and sine of the angle multiplied by the radius
ie:
For angle = 0 to 90 'One quadrant
myradius = 60
RADangle= Rad(angle)
Pixel int(Cos(RADangle)*myradius) , int(Sin(RADangle)*myradius)
Next angle
erbp
Posted: 11:18am 06 Jan 2019
You might be interested in a variant of the above, it uses considerably less program memory space.
The parameters to the Arc subroutine are slightly different, in that it uses a "lw" parameter to specify the required line width for the arc, and that parameter is inserted in the parameter list following the "inradius" parameter. The 'outsize' parameter has been removed. Note that there is no validation of the 'lw' parameter - it should be 1 -> whatever value you need. 0 or negative values will probably result in no arc being drawn!
It also implements line widths greater than 1 by drawing multiple concentric arcs, with each arc having a radius 1 pixel larger than the previous. This seems to provide a better result than the radial lines method, but is probably a bit slower.
The code below includes a test program designed for a 800x480 LCD.
DIM i%, j%, w%, lc%
' This test code is designed to run on a 800x480 LCD panel
CLS RGB(144,144,144)
For j% = 0 To 2
w% = j% + 1 'to test wider line widths, replace the 1 by a larger number
For i% = 0 To 7
select Case i%
case 0
lc% = RGB(White)
case 1
lc% = RGB(Yellow)
case 2
lc% = RGB(Green)
case 3
lc% = RGB(Blue)
case 4
lc% = RGB(Black)
case 5
lc% = RGB(Magenta)
case 6
lc% = RGB(Red)
case 7
lc% = RGB(Cyan)
End Select
Arc((i% * 100),((j% * 150) + 100),80,w%,0,135,lc%)
Next i%
Next j%
END 'of test code
' based on segment code from Peter Mather.
' Parameters are:
' inradius - inner radius of arc circle
' lw - line width (thickness of arc)
' NB: line widths > 1 are achieved by drawing arcs of concentric circles
' with the arc radius increased by 1 pixel each time.
' colour of arc line
Sub Arc(x%, y%, inradius%, lw%, startradial%, endradial%, col%)
' draw arc
DrawArc(x%, y%, inradius%, lw%, startradial%, endradial%, col%)
' draw arc from startradial to 360
DrawArc(x%, y%, inradius%, lw%, startradial%, 360, col%)
' draw arc from 0 to endradial
DrawArc(x%, y%, inradius%, lw%, 0, endradial%, col%)
Sub DrawArc(x%, y%, inrad%, lw%, sr%, er%, col%)
Local c%, i%, r%
For c% = 0 To (lw%-1) Step 1
r% = inrad% + c%
For i%=sr% To er% Step 1
x1%=Sin(Rad(i%-1))*r% + x%
y1%=-Cos(Rad(i%-1))*r% + y%
Pixel x1%,y1%,col%
Next i%
Next c%
Posted: 11:32am 06 Jan 2019
drawing circles and parts thereof is relatively complicated, your initial approach is pretty much the best:
For X=1 To 60
Pixel X,60-SQR(60^2-X^2)
Next X
using trig functions and going around the circle in small steps is a bad approach, as apart from the excessive computational overhead of the trig functions you will end up either plotting the same point multiple times or leaving gaps. there is also the issue of having 'too many' pixels drawn along the arc - within any 2x2 square there should be no more than two pixels filled otherwise you'll get the appearance of 'clumping'.
a full circle can be divided up into eight segments (octants). the segment starting at 12 o'clock and going round to 1:30 should be stepped across horizontally, the two segments from 1:30 to 4:30 should be stepped across vertically, the two segments from 4:30 to 7:30 should be stepped across horizontally, etc.
i'd suggest looking up "bresenham's line algorithm" to understand the clumping problem in the straight-line case, then "bresenham's circle algorithm" for arcs. there is a bit of an explanation here for circles ,that seems to look about right:
https://medium.com/@rakeshnchinta/bresenhams-circle-drawing-algorithm-95792c9f991b
(my own experience is purely with drawing lines)
this is a good example of the old adage: for every complicated problem there is a simple solution that does not work. although, once you get your head around it, bresenham's algorithms are actually quite simple to understand.
rob :-)
Posted: 11:49am 06 Jan 2019
Some time ago I went searching for an efficient algorithm for drawing arcs with variable line width and could not find anything. My maths is not good enough to invent such a thing so if anyone (Peter ?) can find a good solution I would be very interested.
In the meantime I will take a look at panky and erbp's code.
GeoffEdited by Geoffg 2019-01-07
Posted: 12:51pm 06 Jan 2019
https://en.wikipedia.org/wiki/Midpoint_circle_algorithm
void drawcircle(int x0, int y0, int radius)
int x = radius-1;
int y = 0;
int dx = 1;
int dy = 1;
int err = dx - (radius << 1);
while (x >= y)
putpixel(x0 + x, y0 + y);
putpixel(x0 + y, y0 + x);
putpixel(x0 - y, y0 + x);
putpixel(x0 - x, y0 + y);
putpixel(x0 - x, y0 - y);
putpixel(x0 - y, y0 - x);
putpixel(x0 + y, y0 - x);
putpixel(x0 + x, y0 - y);
if (err <= 0)
y++;
err += dy;
dy += 2;
if (err > 0)
x--;
dx += 2;
err += dx - (radius << 1);
rob :-)
Posted: 01:10pm 06 Jan 2019
  Quote  from:
not what is needed
  Quote  efficient algorithm for drawing arcs with variable line width
Posted: 01:45pm 06 Jan 2019
  matherp said
  Quote  from:
not what is needed
the fundamental algorithm is sound.
to achieve what geoff wants, one can:
1) draw two arcs, joined together across the ends with either straight line segments or two 180 degree arcs, and then simply flood-fill within the enclosed area, or,
2) within an octant run the inner and outer arcs within the same loop (suspending drawing either arc as appropriate while the loop counter is out of range), and then instead of drawing points, draw short line segments between inner and outer arcs, or,
3) follow a single arc down the middle with a circular pen, at each step calculating the leading edge of the pen and drawing a 180 degree arc across that edge (windows seems to do it this way).
approach 3) is simple, but will lead to a certain percentage of pixels being drawn twice and is not so great for drawing gauges. 2) is complicated when it comes to dealing with the ends of octants that may have 'triangular' bits to fill in. and 1) while simple requires an effective flood-fill that may be beyond mmbasic's graphics subsystem.
rob :-)Edited by robert.rozee 2019-01-07
Posted: 03:55pm 06 Jan 2019
  Quote  the fundamental algorithm is sound.
The algorithm is the one already used. It works by drawing 1/8th circle arcs starting from the 90 degree points. It cannot draw arbitrary arcs.
Flood fill can't be done without a memory image
You can draw any arbitrary arcs using bezier curves - I posted code to do this previously but the challenge is drawing thick arcs efficiently
Posted: 06:47pm 06 Jan 2019
  Quote  if anyone (Peter ?) can find a good solution I would be very interested.
Here you go - two new drawing commands. Definitely fast enough on the Armmite H7 but haven't tried on anything else.
Parameters for the ARC command
X coordinate of centre of arc
Y coordinate of centre of arc
inner radius of arc
outer radius of arc - can be omitted if 1 pixel wide
start radial of arc in degrees
end radial of arc in degrees
Colour of arc
Parameters for the BEZIER command
X coordinate of start point
Y coordinate of start point
X coordinate of first control point
Y coordinate of first control point
X coordinate of second control point
Y coordinate of second control point
X coordinate of end point
Y coordinate of end point
Colour of curve
Test code:
CLS
bezier 10,10,106,80,212,80,309,10,rgb(yellow)
bezier 10,230,106,150,212,150,309,230,rgb(yellow)
bezier 10,10,80,80,80,160,10,230,rgb(green)
bezier 309,10,239,80,239,160,309,230,rgb(green)
text 85,110,"Cubic Bezier Curves"
pause 5000
CLS
timer=0
for i=0 to 99 step 4
Arc mm.hres/2,mm.vres/2,20+i,,325+2*i,5+5*i,rgb(yellow)
next i
print timer 'takes 30mSec on Armmite H7
pause 5000
CLS
timer=0
arc mm.hres\2,mm.vres\2,100,110,315,45,rgb(red)
arc mm.hres\2,mm.vres\2,100,110,45,315,rgb(green)
print timer ' takes 12mSec on Armmite H7
C code, can be included in draw.c:
void bezier(float x0, float y0, float x1, float y1, float x2, float y2, float x3, float y3, int c){
float tmp,tmp1,tmp2,tmp3,tmp4,tmp5,tmp6,tmp7,tmp8,t=0.0,xt=x0,yt=y0;
int i, xti,yti,xtlast=-1, ytlast=-1;
for (i=0; i<1000; i++)
tmp = 1.0 - t;
tmp3 = t * t;
tmp4 = tmp * tmp;
tmp1 = tmp3 * t;
tmp2 = tmp4 * tmp;
tmp5 = 3.0 * t;
tmp6 = 3.0 * tmp3;
tmp7 = tmp5 * tmp4;
tmp8 = tmp6 * tmp;
xti=(int)xt;
yti=(int)yt;
xt = ((((tmp2 * x0) + (tmp7 * x1)) + (tmp8 * x2)) + (tmp1 * x3));
yt = ((((tmp2 * y0) + (tmp7 * y1)) + (tmp8 * y2)) +(tmp1 * y3));
if((xti!=xtlast) || (yti!=ytlast)) {
DrawPixel(xti, yti, c);
xtlast=xti;
ytlast=yti;
t+=0.001;
void SmallArc(float x, float y, float r, float a1i, float a2i, int col){
// First compute all four points for an arc that subtends the same total angle
// but is centered on the X-axis
float a1,a2,a,x1,y1,x2,y2,x3,y3,x4,y4,f,ar,cos_ar,sin_ar ;
float x2i,x3i,y2i,y3i ;
float pidiv2=PI_VALUE/2.0, k = 0.5522847498 ;
a1=Rad(a1i)- pidiv2 ;
a2=Rad(a2i)- pidiv2 ;
a = (a2-a1) / 2.0 ;
x4 = r * cos(a) ;
y4 = r * sin(a) ;
x1= x4 ;
y1= -y4 ;
f = k * tan(a) ;
x2 = x1 + f * y4 ;
y2 = y1 + f * x4 ;
x3 = x2 ;
y3= -y2 ;
// Now find the arc points actual locations by computing x1,y1 and x4,y4
// and rotating the control points by a + a1
ar = a + a1 ;
cos_ar = cos(ar) ;
sin_ar = sin(ar) ;
x1 = r * cos(a1) + x ;
y1 = r * sin(a1) + y ;
x2i = x2 * cos_ar - y2 * sin_ar + x ;
y2i = x2 * sin_ar + y2 * cos_ar + y ;
x3i = x3 * cos_ar - y3 * sin_ar + x ;
y3i = x3 * sin_ar + y3 * cos_ar + y ;
x4 = r * cos(a2) + x ;
y4 = r * sin(a2) + y ;
bezier(x1,y1,x2i,y2i,x3i,y3i,x4,y4,col) ;
void cmd_arc(void){
// Parameters are:
// X coordinate of centre of arc
// Y coordinate of centre of arc
// inner radius of arc
// outer radius of arc - omit it 1 pixel wide
// start radial of arc in degrees
// end radial of arc in degrees
// Colour of arc
int x, y, r1, r2, c;
float f, rad1, rad2, rstart;
getargs(&cmdline, 13,",");
if(Option.DISPLAY_TYPE == 0) error("Display not configured");
if(!(argc == 11 || argc == 13)) error("Argument count");
x = getinteger(argv[0]);
y = getinteger(argv[2]);
r1 = getinteger(argv[4]);
if(*argv[6])r2 = getinteger(argv[6]);
else r2=r1;
if(r2 < r1)error("Inner radius < outer");
rad1 = getnumber(argv[8]);
rad2 = getnumber(argv[10]);
if(argc == 13)
c = getint(argv[12], 0, WHITE);
else
c = gui_fcolour;
while(rad2<rad1)rad2+=360;
for(f = r1 ; f<= r2; f+=1.0){
rstart=rad1;
while(rad2 - rstart > 90){
SmallArc(x , y , f , rstart, rstart+90 , c);
rstart+=90;
SmallArc(x , y , f , rstart, rad2 , c);
void cmd_bezier(void) {
// X coordinate of start point
// Y coordinate of start point
// X coordinate of first control point
// Y coordinate of first control point
// X coordinate of second control point
// Y coordinate of second control point
// X coordinate of end point
// Y coordinate of end point
// Colour of curve
int xx0, yy0, xx1, yy1, xx2, yy2, xx3, yy3, c;
getargs(&cmdline, 17,",");
if(!(argc==15 || argc==17))error("Argument count");
xx0 = getint(argv[0],0,HRes-1);
yy0 = getint(argv[2],0,VRes-1);
xx1 = getinteger(argv[4]);
yy1 = getinteger(argv[6]);
xx2 = getinteger(argv[8]);
yy2 = getinteger(argv[10]);
xx3 = getint(argv[12],0,HRes-1);
yy3 = getint(argv[14],0,VRes-1);
c = gui_fcolour; // setup the defaults
if(argc > 15 && *argv[16]) c = getint(argv[16], 0, WHITE);
bezier(xx0, yy0, xx1, yy1, xx2, yy2, xx3, yy3, c);
Edited by matherp 2019-01-08
