Local Time 01:03 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Drawing better lines
karjo238
Posted: 05:15am 05 Jan 2019
Hello there again, for the umpteenth time, it seems. As you know, ?I think I've mentioned it?, I'm writing Missile Command for the Colour Maximite, and having a great time flexing my rusty code writing skills in the process.
One of the most important parts of Missile Command is the lines that go hither and thither blowing stuff up. Because these lines grow over time rather than being drawn all at once, I had to find some code that would let me do this. I found this C# code:
public void line(int x,int y,int x2, int y2, int color) {
int w = x2 - x ;
int h = y2 - y ;
int dx1 = 0, dy1 = 0, dx2 = 0, dy2 = 0 ;
if (w<0) dx1 = -1 ; else if (w>0) dx1 = 1 ;
if (h<0) dy1 = -1 ; else if (h>0) dy1 = 1 ;
if (w<0) dx2 = -1 ; else if (w>0) dx2 = 1 ;
int longest = Math.Abs(w) ;
int shortest = Math.Abs(h) ;
if (!(longest>shortest)) {
longest = Math.Abs(h) ;
shortest = Math.Abs(w) ;
if (h<0) dy2 = -1 ; else if (h>0) dy2 = 1 ;
dx2 = 0 ;
int numerator = longest >> 1 ;
for (int i=0;i<=longest;i++) {
putpixel(x,y,color) ;
numerator += shortest ;
if (!(numerator<longest)) {
numerator -= longest ;
x += dx1 ;
y += dy1 ;
} else {
x += dx2 ;
y += dy2 ;
and converted it into MMBasic. The two major changes I made were for it to be drawn one pixel at a time, and split it into two functions, one that is only run once, and one that it run every cycle:
Sub lineCode(a1,a2,a3,a4,a5,a6,a7,a8,a9,a10,a12,a13)
If a12 + a13 = Timer Then
a12 = Timer
Pixel(a1,a2) = 7
Rem a9 = a9 + a8
inc a9,a8
If Not(a9 < a7) Then
a9 = a9 - a7
a1 = a1 + a3
a2 = a2 + a4
Else
a1 = a1 + a5
a2 = a2 + a6
Rem a10 = a10 + 1
inc a10
Sub initMiss(a1,a2,a3,a4,a5,a6,a7,a8,a9,a10,a11,x2,y2)
w = x2 - a1
h = y2 - a2
If w<0 Then a3 = -1 Else a3 = 1
If h<0 Then a4 = -1 Else a4 = 1
If w<0 Then a5 = -1 Else a5 = 1
a7 = Abs(w)
a8 = Abs(h)
If Not(a7 > a8) Then
a7 = Abs(h)
a8 = Abs(w)
If h<0 Then a6 = -1 Else a6 = 1
a5 = 0
a9 = RShift(a7,1)
a10 = 0
The problem I have right now is that the code requires 9 data points to be able to compute the next point for the line, and for the purposes of Missile Command, I need to add a further 6 data points to make it work in game. Basically, it works - it looks really nice - but it's not efficent.
I read somewhere (I can't find the reference now) that you can write C code, and link that to your code, and have that C code run much faster. What I'd like to do is modify that C code to something like:
- function a1,a2 = linePoint(x1,y1,x2,y2,p)
- given the start coordinates x1,y1 and end coordinates x2,y2, return the coordinates of point p along the line generated by Bresenhams algorithm.
The function would have to iterate maybe 60 or 70 times, but it would be faster in C as opposed to MMBasic.
Is this at all remotely possible? Is it really that much more efficient? I fully admit I've dug a hole for myself here, and what I'd like to do to get out of the hole is waaaaaaaaaay above my pay grade, so if anybody here has any suggestions, they'd be greatly appreciated.
Many thanks,
Joseph
Posted: 07:31am 05 Jan 2019
In case things like inc and RShift
are calling functions/subs then that is an easily avoided overhead.
I don't know if Cfuncs are available on the CM but if they are then matherp did a number of tutorials which are on TBS.
Posted: 09:33am 05 Jan 2019
Unfortunately CFunctions are not available on the Maximite (only on the Micromite).
Currently the only way to add C code to the Maximite is to download the source, add your code and recompile.
twofingers
Posted: 09:36am 05 Jan 2019
  JohnS said   ...
CFunction are not available for the Maximites. AFAIK a there are no plans (by Geoff) to change that.
Michael
twofingers
Posted: 09:37am 05 Jan 2019
Geoff was faster!
karjo238
Posted: 09:58pm 05 Jan 2019
Ah drat Alrighty then, time to reconsider what I want to do at this point. I'll request a copy of the source code anyhow, because it occurred to me I *might* be able to take Geoffs existing line code and modify it for my needs, but I may also be in over my head.
Many thanks,
Joseph.
