Local Time 01:03 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Display, displays and more displays...
panky
Posted: 06:27am 03 Jan 2019
Does anyone have a list of all displays that are supported by MMBasic and which version of MMBasic supports them including a brief note of size and resolution?
panky
Trevorc
Posted: 11:10am 03 Jan 2019
Hi Panky,
No sorry , I don't have a list , but in the EPE Magazine August 2017, Geoff did an
11 page article on the Micromite Plus and Explore 64.
At the end (Pages 37-38)he has listed "Supported LCD Panels".
May be good for what you need.
Happy new year.
Posted: 10:00pm 03 Jan 2019
Do you mean just the displays that are natively supported, or ALL displays including the ones that our resident guru(matherp) has written drivers for?
panky
Posted: 10:54pm 03 Jan 2019
I think it would be usefull to have a list of all displays that are supported, both stable (official) and development, which version of MM they are supported/developed on and which chip. It's not a small task and it could also include which board platform has inbuilt connections.
I intend to start on it today and will post progress.
panky.
Posted: 02:08am 04 Jan 2019
I would like to have a copy of that when you are finished.
So many different display drivers have been written now, it is hard to keep track of them all.
panky
Posted: 06:57am 04 Jan 2019
My efforts to date. Please feel free to edit/update/correct and re-post.
panky
2019-01-04_165752_Display_Summary.zip
Posted: 11:40am 04 Jan 2019
good work panky it is extremely useful having all the information in one spreadsheet or chart, as the number of displays will over time continue to expand.
might i suggest that the column 'Platform/MM Version Support (stable or beta)' be split up into a number of columns for each micromite variant: MM2/MX170, MM+/MX470, MZ, RPi, armH7, armL4, etc. into each cell then have a short code: INT (internal support), CFn(external support via cfunction), BAS (external support via basic code), b INT / b CFn / b BAS (betas).
for any displays that use external support (cfunction or basic), it would be really good if geoff (are you there geoff?) could maintain the latest driver on his website as the 'master version'. while it is fine getting code out there in attachments to forum posts, those posts quickly get lost amongst the masses.
rob :-)
disco4now
Posted: 12:26pm 04 Jan 2019
Hi Panky
Thanks for starting this off. I have spent the afternoon learning how to set up a table in the Fruit of the Shed. I have put a few samples in there based on your research and some things I have recently used.
It allows links to be embedded, you can link the relevant TBS threads, purchase options drivers etc.
The wiki table can be maintained by any one with an interest so work could be shared.
Does the FoS wiki look useful for this.I find being able to pull up relevant threads to be very useful.
LCD Display Summary on Fruit of the Shed
Gerry
F4 H7FotSF4xGT
panky
Posted: 12:09pm 05 Jan 2019
Gerry,
I really like what you have done on TFOTS - I will try to add to it when I get a chance and to keep the spreadsheet in-sync (mainly for my own off-line use but happy to share).
Doug.
