Local Time 23:01 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Code example for VL53L0X?
sagt3k
Posted: 12:16pm 01 Dec 2018
Hi to Everybody
Does anyone have experience or simple code to show me to work with this device?
VL53L0X Time-of-Flight ranging and gesture detection sensor
AntonioEdited by sagt3k 2018-12-02
Posted: 12:54pm 01 Dec 2018
Using a web search I see code on the net - what's wrong with that?
sagt3k
Posted: 02:02pm 01 Dec 2018
Hi JohnS
I have problem with registers maps.
Do you have clear documentation ?
Antonio
Posted: 03:53pm 01 Dec 2018
I'm lost here as to what you want - read the data sheet?
It's I2C and it states the address.
sagt3k
Posted: 09:08pm 01 Dec 2018
Hi JohnS
My problem is to find documentation on register map
Here is the code, really basic, but I can not find documentation on the registers map to understand if I can improve the noise I have in reading.
Dim from As integer = 30
Dim maxregs As integer = from+2
Dim buff(maxregs) As integer
Dim R As Float
SetPin 38,dout : Pin(38)=1
ReadI2C
Pause 50
Sub ReadI2C
I2C OPEN 400, 1000
I2C WRITE &H29, 0, 2, 0, 1
I2C READ &H29, 0, maxregs,buff()
If MM.I2C Then Print "Slave did not respond"
I2C CLOSE
x = (buff(from)<<8)+buff(from+1)
If X>20 Then Print Timer,Str$(x/10,3,1)"cm"
This is the result,with the sensor still and placed in front of a fixed and smooth object:
597845 69.8cm
598001 68.1cm
598055 67.8cm
598211 68.9cm
598265 67.9cm
598319 67.6cm
598373 67.2cm
598529 67.5cm
598583 68.3cm
598637 67.8cm
598691 67.1cm
598745 69.5cm
598799 68.0cm
598853 66.9cm
598907 67.6cm
599063 67.8cm
599117 69.1cm
599171 67.8cm
599225 68.3cm
599279 68.6cm
599333 70.2cm
599387 67.3cm
599543 66.7cm
599597 68.7cm
599651 68.0cm
Antonio
