Forum Index : Microcontroller and PC projects : E-28 Project.
Think an E-28 will be just perfect for a similar project. Just right for the 18 year old that leaves here every 2nd weekend & leaves his alarm clock one, buried in the quake ridden bedroom... Sensors for light & motion.... Probably just a random beep or two required.... Edit, 10 seconds later..... Maybe also some light switch over-ride! |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10081 |
I see there is something similar to this in this month's issue of DIYODE(page 32) based on the same annoy-a-tron device. I'm sure they work OK, but you might not once the person you have planted this on finds out what you have done. IE: You could be in for a punch up the konk.I'm all for a good joke and a laugh - during daylight hours, but something like this can be used to actually keep people up at night trying to find the source of the sound - many people will NOT thank you for that kind of prank if they miss out on their much needed sleep, and they also won't see the funny side either. I wouldn't. A good way to lose friends, I expect. ![]() Smoke makes things work. When the smoke gets out, it stops! |
Lol, there in lies the inspiration... The intended victim has also read the article & is about to take up the Spy Vs Spy challenge. |
