circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 310
Posted: 02:23pm 16 Nov 2018
Having now been totally successful with the 28 and 44 pin Micromites; 100 pin Micromite Plus, Armite H7 and with the latest Armite L4 on the bench, I have started constructing the Micromite Extreme and reached a problem; the crystal oscillator.
The Micromite eXtreme manual recommends an Epson SG8002DCPHB24MHz but I cannot locate this part. Can anyone point me to a suitable oscillator (preferably on the UK-RS website or Farnell) for this purpose?
I also note that the Epson SG8002DCPHB24MHz appears to be a 5 volt device. How is this reconciled with the PIC32MZ2048EFH144-250I/PL 3.3 volt chip?
I have used crystals+capacitors on many chips in the past but these crystal oscillators are confusing me somewhat. I gather that there are two pins on one side which I presume just connect to Vdd/Vss and of the other two, one is the OSC output and the other goes to ground. Do I need to feed 5V into the oscillator for a 3.3v chip?
Pointers in the right direction would be most appreciated.
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12084
Posted: 02:39pm 16 Nov 2018
On the MMX144 backpack I either use a 5V oscillator fed with 5V and with a potential divider on the output or a 3.3V part. The PCB has pads for both. The problem is that there aren't any DIP 3.3V versions. However, a 7x5mm 3.3V oscillator of which there are many will fit on a SOIC-DIP adapter. Leave the output select pin unconnected.Edited by matherp 2018-11-18
Posted: 07:03pm 16 Nov 2018
Thank you, Peter, for your most rapid and helpful reply. I have not used these components before, so could you indicate if the following are suitable; If I take the DIP route and go for 5V and a potential divider then I could use; https://uk.rs-online.com/web/p/crystal-oscillators/4785783/
If I go for the 3.3 volt part then this would be suitable; https://uk.rs-online.com/web/p/crystal-oscillators/4788760/ - it seems to be 7x5mm and therefore would mount on a SOIC-DIP as you propose.
Sorry to be a pain, but I am on quite a roll with successfully hand-soldering 44, 64 and 100 pin chips and as I move to your 144 pin Micromite eXtreme I do not want to mess up with this key component.
Posted: 07:31pm 16 Nov 2018
Either of those should be fine, 3.3V version probably preferred.
