Local Time 21:54 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMedit won’t run on my Win 7 64-bit
factotum
Posted: 10:45am 14 Nov 2018
See ERROR.LOG below. It initially produced the 5003 error. I then uninstalled and reinstalled with the memory bug fix box ticked. It then produced the 1001 error in Smalltalk/V.
I don't know if this is relevant but I always run with Data Execution Prevention enabled. I'd be very reluctant to make an exception to that policy.
Error log timestamp 11/14/2018 10:29:02
Message 5003:
unable to allocate virtual address space.
Error log timestamp 11/14/2018 10:30:13
The registers were:
EIP = 0x0290020d
ESP = 0x0018fea8
EBP = 0x00000000
EAX = 0x08ea4444
EBX = 0xffffe001
ECX = 0x00000100
EDX = 0x02aaf000
EDI = 0x00000001
ESI = 0x08ea4444
CS = 0x00000023
DS = 0x0000002b
ES = 0x0000002b
SS = 0x0000002b
End Registers
Message 1001:
a non-continuable protection violation has occurred. Check ERROR.LOG file.
panky
Posted: 11:06am 14 Nov 2018
@factotem,
I've been running MMEdit (the last dozen versions up to the latest) under Win 7-64 Pro on an Asus laptop for years without any problems so I suspect it is the environment you have configured on your PC that is causing the issues.
If it is not possible to get MMEdit running, you might give Micromite Console by sagt3k (a few posts below) a try.
panky.
factotum
Posted: 03:54pm 14 Nov 2018
Thanks. I don't normally use MMedit, as prefer to use my own editor and TeraTerm. So it isn't essential.
I haven't configured my PC in any particular way, except for setting DEP on.
Posted: 08:02pm 14 Nov 2018
It is definitely your DEP settings.
You could try installing MMEdit into a folder that is NOT in "Program Files"
Depending on how tight you have DEP set, that might work.
factotum
Posted: 08:15pm 14 Nov 2018
Ok, thanks.
