Forum Index : Microcontroller and PC projects : code OK in MMDOS 5.04.08; 5.04.09 fails
The code below, sent to me by Paul_L, runs on his PC with 5.04.08. On mine, with 5.04.09, it fails with an out of memory error. [code] DOS MMBasic Ver 5.04.09 Copyright 2011-2018 Geoff Graham Program: 4K ( 0%) used 508K free (162 lines) Variables: 8K (24%) used 23K free (124 variables) General RAM: 4K ( 0%) used 508K free [55] dds(Mid$(Date$,4,2)+"/"+Mid$(Date$,1,2)+"/"+Mid$(Date$,7,4)):ddc Error: Not enough memory > [/code] I inserted the line, "PRINT "" : memory" before the "NEXT it" line to try to see what was happening, and it ran to completion. [code] ' DataDumpTest.bas Option EXPLICIT Option DEFAULT INTEGER Option BASE 1 Dim i, j, k, L, x, y, in$, PIC, iSimRecNo, st$, it Dim Hstg, TkTarget, FS, FSo Dim Xok, XFAIL '@@@@ Dim MANBLR, MODE$="O", KEYSEEK$="UAW1" Dim UtilStat, GenStat ' for DOS test only Dim WeM, WeD, SeM, SeD Dim WeM2, WeD2, SeM2, SeD2 Dim WINTER, oDate$, DOY, FrWgen, FrWgen2, KEYPOINTER Dim oatStrt, tkStrt, ratio! 'slope settings Dim oatStrt2, tkStrt2, ratio2! Dim FGxSensors = 0, FGxUI = 0, FGxDate = 0, FGxFileSetsData = 0 ' LB x181010 If MM.Device$ <> "DOS" Then PIC=1 'PL???? PIC is used in many places ' calculated values Dim SupHt, SubCl, FrGain, TkGain, YdGain, TkBTU, YdBTU ArrayElementPointers: '========================================================= Const PydF=1,PtkF=2,PcpF=3,PcpR=4,PydQ=5,PtkQ=6,Pha=7,Pgr=8,Poa=9 'S(n) Z(n) Const PydR=10,PtkR=11,PtkC=12,PxvF=13,PxvR=14,Putil=15,Pgen=16 'T!(n,?) P(n) Const Ptmp=1,Perr=2 'T!(?,n) Const Pwlo=1,Pwhi=2,Pslo=3,Pshi=4 'S(?,n) Z(?,n) Const Prtc=1, Ploop=2, Pfrho=3,Ppre=4,PflSns=5, Pstab=6 Const Ppost=7, PdataSS=8, PdataDU=9 'D(n,?) Const Pset=1,Psmn=2,Psmx=3,Pmnlo=4,Pmxhi=5,Pstat=6, PEnd=7 'D(?,n) Const Pfc=1,Pfrr=2,Pydp=3,Pjp=4,Pahp=5,Pgas=6,Pnav=7 'O(n,?),OPS(n) Const Ppin=1,Pnow=2,Pneed=3,Pprob=4,Pposs=5,PtOn=6 'O(?,n) Const PtOff=7,PttOn=8,PttOff=9 'O(?,n) DimArrays: '==================================================================== ' settings temp in pins delays status out pins trips Const kSx=9,kSy=4, kTx=16,kTy=2, kPx=17, kDx=9,kDy=7, kOx=7,kOy=9, kZx=6,kZy=4 Dim S(kSx,kSy), T!(kTx,kTy), P(kPx), D(kDx,kDy), O(kOx,kOy), Z(kZx,kZy) Open "GEOdump.csv" For output As #2 Restore DDdata For x=1 To 14 Read st$:Print #2,st$; Next x Print #2,"" memory for it=1 to 30 ' 30 'dds(Mid$(Date$,7,4)+Mid$(Date$,4,2)+Mid$(Date$,1,2)):ddc 'dds(Mid$(Date$,4,2)+Mid$(Date$,1,2)+Mid$(Date$,7,4)):ddc 'dds(Date$):ddc dds(Mid$(Date$,4,2)+"/"+Mid$(Date$,1,2)+"/"+Mid$(Date$,7,4)):ddc dds(Time$):ddc:dd(NOW()):dds(MODE$):ddc:dd(MANBLR,1) dds(KEYSEEK$):ddc:dd(KEYPOINTER,2) For i=1 To 7 DD(O(i,Pposs),1) Next i dd(SupHt,5) dd(SubCl,5) dd(FrGain,5) dd(TkGain,5) dd(YdGain,5) dd(TkBTU,5) dd(YdBTU,5) For x=1 To kTx '16 ydF to gen dd(T!(x,Ptmp),3,1) Next x '16 nnn.n For x=1 To 7 'RtcStat to PostEnd For y=6 To 7 dd(D(x,y),7) Next y Next x '7 of 9 dd(FS,2) for x=1 to kZx '6 TRydF to TRtkQ for y=1 to kZy '4 dd(Z(x,y),1) Next y '4 next x '6 For x=1 To kOx '7 FRCnnpp to NAVnnpp For y=2 To 5 dd(O(x,y),1) Next y For y=6 To 9 dd(O(x,y),6) Next y Next x Print #2 ' print "" : memory next it Close #2 print "" : memory End DDdata: Data "Date ,Time ,Timer ,M,B,SEEK,KP,F,R,Y,J,A,G,N," Data "supHt,subCl,FGain,TGain,YGain,TkBTU,YdBTU," Data " ydF, tkF, cpF, cpR, ydQ, tkQ, hall, grnd," Data " oat, ydR, tkR, tkC, xvF, xvR, util, gen," Data "RtcStat, RtcEnd,LoopStt,LoopEnd,FrHoStt,FrHoEnd,PreStat," Data " PreEnd,FlowStt,FlowEnd,StabStt,StabEnd,PostStt,PostEnd," Data "FS,TRydF,,,,TRtkF,,,,TRcpF,,,,TRcpR,,,,TRydQ,,,,TRtkQ,,,," Data "FRCnnpp,,,, on, off, t on, t off," Data "YDPnnpp,,,, on, off, t on, t off," Data "FRRnnpp,,,, on, off, t on, t off," Data " JPnnpp,,,, on, off, t on, t off," Data "AHPnnpp,,,, on, off, t on, t off," Data "GASnnpp,,,, on, off, t on, t off," Data "NAVnnpp,,,, on, off, t on, t off," Sub dd(v,m,n,c$) If m=0 Then m=3 If n=0 Then n=0 If c$="" Then c$="0" Print #2, Str$(v,m,n,c$)+","; End Sub 'dd(n) Sub dds(ss$) Print #2, ss$; End Sub 'dds(ss$) Sub ddx Print #2, "/"; End Sub 'ddx Sub ddc Print #2, ","; End Sub 'ddc Function NOW() '^seconds since 1/1/2018 using date$ dd-mm-yyyy & time$ hh:mm:ss Local n.yr,n.mo,n.da,n.hr,n.mn,n.s,y,n.doy,n.t.da,n.t.hr,n.t.mn,n.t.s n.yr=Val(Mid$(Date$,7,4)):n.mo=Val(Mid$(Date$,4,2)):n.da=Val(Mid$(Date$,1,2)) n.hr=Val(Mid$(Time$,1,2)):n.mn=Val(Mid$(Time$,4,2)):n.s=Val(Mid$(Time$,7,2)) For y=2018 To n.yr-1 n.doy=DoYi(y,12,31):n.t.da=n.t.da+n.doy Next y n.doy=DoYi(n.yr,n.mo,n.da) n.t.da=n.t.da+n.doy n.t.hr=(n.t.da*24)+n.hr n.t.mn=(n.t.hr*60)+n.mn NOW=(n.t.mn*60)+n.s End Function 'NOW() Function DoYi(DoYiy%,DoYim%,DoYid%) DoYi= DoYid% + Int((DoYim%-1)*30.57+0.5) If DoYim%>2 Then DoYi=DoYi-1 If (DoYiy% Mod 4)>0 Then DoYi = DoYi-1 'not leap year If (DoYiy% Mod 100)=0 Then DoYi = DoYi-1 'not leap century If (DoYiy% Mod 400)=0 Then DoYi = DoYi+1 'leap 4th century EndIf End Function 'DoYi(DoYy%,DoYm%,DoYd%) Function DoYset(DoYd$) Local DoYsd,DoYsm,DoYsy DoYsd=Val(Mid$(DoYd$,1,2)) DoYsm=Val(Mid$(DoYd$,4,2)) DoYsy=Val(Mid$(DoYd$,7,4)) DoYset=DoYi(DoYsy,DoYsm,DoYsd) End Function 'DoYset(DoYsd$) [/code] PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Paul_L Guru Joined: 03/03/2016 Location: United StatesPosts: 769 |
Yep Lance, it runs to completion here with or without the extra print command. Things that make you go hmmmmmm .... Paul in NY DOS MMBasic Ver 5.04.08 Copyright 2011-2017 Geoff Graham > load "datadumptest.bas" > RUN Program: 4K ( 0%) used 508K free (161 lines) Variables: 8K (24%) used 23K free (124 variables) General RAM: 4K ( 0%) used 508K free > |
I have tracked this one down and reported the solution in this thread: https://www.thebackshed.com/forum/forum_posts.asp?TID=10720&PN=1&get=last#126794 Geoff Graham - http://geoffg.net |
Brilliant work Geoff! Paul in NY |
