Local Time 16:20 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : $48 Ebay Battery Monitor - Caravans?
ion507
Posted: 05:21am 29 Aug 2018
I saw this posted on a camper trailer Facebook page. For the price, it may be just what someone is looking for as an easy fit for a basic 12V setup. 3 parts to it are current transformer, electronics module and the display connected by a USB cable. Obviously it won't do the job of a $500 Battery Management System.
www.ebay.com.au/itm/Wireless-Voltmeter-Ammeter-DC-120V-100A-VOLTAGE-AMP-AH-SOC-Power-Battery-Tester/163091909578
Their description:
Battery Status At A Glance.
Charging status indicator, looks like a smartphone.
Combines many functions in one, Dual display
Voltage (V), Current (A), Capacity (AH)
Power (W/KW), Energy (KWH)
Temperature (C), Working Hours (H)
By turning External device/Relay on and off, it can control external devices, such cut off Power input.
Trigger external Relay (Not included) when the reading reach preset value.
[OVP] Over Charge Voltage protection
[LVP] Over Discharge Voltage protection
[OCP] Over Discharge Current protection
[NCP] Over Charge Current protection
Come with a Through-hole Current transformer, it doesn't require shunt.
The current sensor can be placed on the Positive or Negative side of power.
Reverse polarity protection.
Doesn't require isolated power, self-powered 6-80V.
Nondestructive installation, it is very easy to install.
Posted: 05:33am 29 Aug 2018
  Quote  Come with a Through-hole Current transformer, it doesn't require shunt.
I don't think so.
It will be a hall effect sensor.
Provided it can be configured for the different battery types, the price is good.
ion507
Posted: 10:50am 29 Aug 2018
Don't know if can be configured for different battery types, probably just set the battery capacity. Must be able to change those voltage and current protection levels too. Here's the current sensor:
Posted: 10:54am 29 Aug 2018
The listing mainly refers to a Hall effect sensor, so it will be :)
Posted: 12:32pm 29 Aug 2018
Very interesting. I don't see where it explains what about it is "Wireless". Has anyone found the "English manual"?
This Aliexpress page has more info: https://www.aliexpress.com/item/DC-120v-Wireless-voltage-meter-Gauges-ammeter-Voltmeter-Battery-Charging-coulometer-capa city-Power-detector-Tester/32858623812.html?spm=2114.search0104.8.9.5b9b7b66csmh87&priceBeautifyAB=0
The wireless part refers to communication between the display and detection modules.
Two relays can be controlled by settings to cut charging circuit and/or load circuit (as I read it).
Edited by lizby 2018-08-30
mikeb
Posted: 12:07am 30 Aug 2018
Have ordered two of them.
On the slow boat though.
Seller says it comes with an English manual but is probably chinglish.
The website photos show a rear view which clearly shows a plugin wifi module.
There are 10 kinds of people in the world.
Those that understand binary and those that don't.
Turbo46
Posted: 01:40am 30 Aug 2018
This device is also available from Banggood Here - There is an Instructions pdf for download.
BillEdited by Turbo46 2018-08-31
Bill7300
Posted: 11:39pm 30 Aug 2018
Banggood is restocking at the moment though ....
the other Bill
Benzol
Posted: 04:54am 31 Aug 2018
Banggood have a couple of different units. I have this one but not installed yet.
https://www.banggood.com/PZEM-031-DC-6_5-100V-20A-4-in-1-Digital-Display-LCD-Screen-Voltage-Current-Power-Energy-Meter-p -1111791.html?rmmds=myorder&cur_warehouse=CN
db
