Local Time 16:22 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : help me with MMEdit V3.7.0
alexandergb
Posted: 04:56pm 28 Aug 2018
Dear friends!
Can anybody please help me solve a problem?
When I use MMEdit (regardless portable or installed version) I collide with problem:
pressing the 'Load and Run current code' button (far right) caused error
XMODEM RECEIVE
Syntax error
in the Upload Progress window.
I don't know what must I do in order to set the target filename
(because the XMODEM RECEIVE command demands the filename, it is obligatory).
How to set this filename and remove the syntax error.
Posted: 05:07pm 28 Aug 2018
What Micromite are your using? You need to set the syntax drop down to the correct part (top right of menu items).
alexandergb
Posted: 05:12pm 28 Aug 2018
  matherp said   What Micromite are your using? You need to set the syntax drop down to the correct part (top right of menu items).
I use COLOR MAXIMITE (not Micromite!) with basic v4.5c version.
Posted: 06:50pm 28 Aug 2018
Make sure the syntax is set to "Maximite_V4.5"
Edited by matherp 2018-08-30
alexandergb
Posted: 09:46am 29 Aug 2018
  matherp said   Make sure the syntax is set to "Maximite_V4.5"
Thank You! All of functions operates correctly.
