Local Time 15:13 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC32 Programming Connector for MM+
sawasdee01
Posted: 10:25am 21 Aug 2018
I was wondering if anyone could help me with a question about the options for connecting a PICkit Programmer to the MM+ PIC32MX470512H (ie 64 pin).
In the MM+ manual it states that we should use PGEC1 and PGED1. However, these clash with Com1Tx and Com3Tx. Whilst this is probably fine for a lot of scenarios, I would like to retain full access to the programming port during run time.
I was wondering whether it is possible to relocate my programming port to pins 17 and 18 - ie PGEC2 and PGED2 without having to have a new HEX image for MM+? This would allow me free and unhindered access to Com 1.
Best wishes to all.
Sawasdee
Azure
Posted: 10:54am 21 Aug 2018
The pins for programming the firmware are set by Microchip in the chip design. You can choose from 3 pairs of programming pins when programming the DEVCFG0 register.
I have not tried this myself as I just normally use pair PGEC1/PGED1.
The programming pins are only needed during programming and if wired correctly can usually be used for other functions when not in programming mode.
You can find out more about this in the PIC32MX470 reference manual as a starting point.
Are you using an existing MM board or making your own?
disco4now
Posted: 11:44am 21 Aug 2018
The MM+ backpack designed by @matherp below uses pins 17 and 18 and many have been built so it is not problem.
MM+ Ultimate Backpack
Gerry
F4 H7FotSF4xGT
sawasdee01
Posted: 12:06pm 21 Aug 2018
Hi Azure,
Many thanks for your reply.
In the Microchip PIC32 Flash Programming Specification it mentions that: "Any pair of programming pins available on a particular device may be used (for programming)"
Somewhere, it also mentions that DEVCFG0.ICESEL is used for the purposes of the "ICE/ICD Comm Communication Channel Select bits".
This is somewhat ambiguous, to say the least - but the way that I read it is that the DEVCFG0.ICESEL only selects which ICSP is used for In Circuit Emulation / Debug and has nothing to do with programming. (There looks to be some 'chicken and egg' stuff with DEVCFG0.ICESEL being able to control programming, anyhow)
This would explain why you can hook up to pretty much any ICSP when you purchase an empty device from Mouser, Farnell, RS, etc, when using MPLABX.
With any luck, this means that I should be fine to hook up to PGEC2 / PGED2 for the purposes of programming MM+ into the PIC32MX470, but any form of 'post boot debug action' with a PICKit is probably a dead duck. This is ok for what I want, as I don't have the source for MM+, anyway.
So, in summary, I think that I should be fine using PGEC2 / PGED2 for programming MM+ into the PIC32MX470 - but I would be very grateful to hear from anyone who might have had first hand experience, before I acquire more solder related injuries.
Best wishes.
Sawasdee
sawasdee01
Posted: 12:08pm 21 Aug 2018
Hi Gerry,
Perfect - this is exactly what I was looking for.
A huge 'thank you'
Best wishes.
Sawasdee
Posted: 12:17pm 21 Aug 2018
yes, you can use ANY pair of PGC/PGD pins. the only restriction is that any other circuitry connected to the pair you use should present minimal loading - this can be accomplished through either circuit design, or simply by using a pair of jumpers you remove when carrying out ICSP programming.
ICE and debugging is another matter, but as you say you're not going down that path anyway.
rob :-)
