Local Time 12:20 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Possible manual typo???
Paul_L
Posted: 08:23am 04 Jul 2018
I just noticed the following in the MMBasic DOS Version Manual V5.04.08.pdf.
  Quote  nbr1 = 123 : nbr2 = 56789
OPEN "numbers.txt" FOR OUTPUT AS #1
PRINT #1, nbr1
PRINT #1, nbr2
CLOSE #1
Again you can read the contents of the file using the LINE INPUT command but then you would need to
convert the text to a number using VAL(). For example:
LINE INPUT #1, a$
LINE INPUT #1, b$
CLOSE #1
x = VAL(a$) : y = VAL(b$)
Shouldn't the second open command be for INPUT?
  Quote  OPEN "numbers.txt" FOR INPUT AS #1
Paul in NY
Posted: 08:29am 04 Jul 2018
Yes, I think so. Well spotted. Hopefully Geoff will see this thread and edit the manual.
Boppa
Posted: 09:04am 04 Jul 2018
I've dropped him an email before about mistakes at the email on his website
Posted: 09:41am 04 Jul 2018
Thanks, well spotted. The Micromite Plus manual suffers from the same error.
I will update them for V5.04.09 (due out soon).
Paul_L
Posted: 09:58am 04 Jul 2018
@geoffg - I figured that it would be replicated in most manuals. Thanks for replying.
