Local Time 10:04 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GFXterm.exe uploaded to doc register
Posted: 02:22pm 12 Jun 2018
I've just uploaded the latest version of GFXterm to the document register:
http://www.thebackshed.com/docregister/ViewDoc.asp?DocID=22
13-june-2018: as well as the 'reset registry' feature moved to alt-8 and the "Esc[J" bug fix, this release introduces a "resume last connection" feature.
pressing the alt-space key combination will attempt to repeat the last successful connection. for instance, if you were last connected to COM3, then pressing alt-space will silently reconnect to that comm port. the same holds for a network port connection.
if already connected, alt-space will disconnect. also, if the last connection can not be repeated, the normal connection dialog will pop up.
rob :-)
Phil23
Posted: 09:59pm 12 Jun 2018
Excellent Rob,
I'm connected in an instant now; Ctrl+Shft+G, followed by Alt Space.
