Local Time 10:02 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Data corruption when using DS18B20s
Posted: 12:30pm 07 Jun 2018
Please be aware there is a likelyhood of data corruption of an array or string on all Micromites (44-pin MM2, all MM+ and MMX) when using the TEMPR or DS18B20 commands with pin numbers of 32 or more. If you limit pin numbers to less than 32 the problem should not occur. NB I do not believe this will only affect multi-dimensional arrays but is likely to corrupt one specific variable depending on the order in which they were defined
I will post an update to fix the problem for the MMX shortly and Geoff is aware of the problem
