Local Time 12:20 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FRAM on RTC module
Quazee137
Posted: 02:55pm 21 May 2018
I have been going over all the work that was done here back in 2016
on using FRAM and started to get the basis of some of it.
Im looking at replacing the 24C32 on RTC modules with FRAM
At DigiKey
FM24V10 128K by 8 $12.76 A1 and A2 no A0
MB85RC1MT 128K by 8 $6.21 A1 and A2 no A0
MB85RC512T 64K by 8 $5.16
FM24V05 64K by 8 $12.64
MB85RC256V 32K by 8 $3.52
CY15B256J 32K by 8 $5.39
So the MB85RC1MT at $6.21 looks good.
Then the next thing hit me what if we could have something like
VARF save
VARF restore
VARF clear
basic thoughs going through my brain
function VARFS(v1,v2,v3,v1$,v2$,ect)
now how to get the names of the vars to be saved
(read some where here there is a way to get a pointer to the var's)
get total size of the var names and data
see if enough space to cont else error
memmap some thing like namevar1,sizevar1,datavar1,ect
address will start at 0 and go from there
write to FRAM (might loop write each namevar datavar) "255 byte $ limit ??"
end function
function VARFR
start adr at 0
read name,size,data
and now how to get data back into the var's
end function
function VARFC
erase FRAM 0 to last used
end function
probably faster as a C-Function (still going over writing C)
THANKS
twofingers
centrex
and all the other that added information to the topic.
Quazee
Edited by Quazee137 2018-05-23
Quazee137
Posted: 10:30pm 03 Jun 2018
Here's and update to where Im at with this
the basic idea
VARF "s","v1 w x$ y() z$()"
Print or test vs
VARF "r" restore if "r","w z$()" then selective restore
Print "varf status ";vs
VARF "c"
if vs then Print "error ";vs
Sub VARF op$,myvar$
'test op$ for s,r,c
'extract var names from myvar$ ? I think only global vars are safe
'find in vartable
's=copy to FRAM vname,vsize,vdata
'r=copy from FRAM vdata
'c=clear FRAM
'0 no error
'if any errors save in vs
learning the vartable
showvar.bas
'The showvar code is gleamed from TassyJim short array code. Thanks again for helping me to some what understand things.
'I am still trying to figure out the rest of the table
'the init code is ripped from my quad tower controller test.
'What I am trying to do is copy the var functionality to FRAM's.
'my test chip is 8k by 8 and on the DS3231 RTC module and that is 4 times the flash space of the 170
'later I will try the larger FRAM 128K by 8. Thats a lota storage for the 28 pin Mite. Still reading pdf
'OPTION COLOURCODE ON
'OPTION DISPLAY 24,132 easier to see it all
Option base 1
Option EXPLICIT
Dim test(2,2,2,2,2,2,2) length 2
'data arrays
Dim fn=100,r$(fn) length 1, f$(fn) length 1, d$(fn) length 4, s$(fn) length 4
Dim day$(fn) length 2
'runtime display vars
Dim rn$(4) length 9,dd$(4) length 4, ds$(4) length 4, df$(4) length 1
Dim c,count(4),fsc
'touch
Dim tx,ty,itx,ity,itx2,ity2,icx,icy,row,srow,col,penup=1,pendown=0
' mis keyboard vars "testing wip they cant decide which one to use"
Dim key$(45)=("1","2","3","4","5","6","7","8","9","0",".","q","w","e","r","t","y","u","i","o","p","*","a","s","d","f","g","h ","j","k","l",":","/","z","x","c","v","b","n","m","#","-","^","^"," ") length 1
Dim ar$(36)=("00","01","02","03","04","05","06","07","08","09","10","11","12","13","14","15","16","17","18","19","20","21"," 22","23","00","05","10","15","20","25","30","35","40","45","50","55")
Dim week$(35)=("Sun","Mon","Tue","Wed","Thr","Fri","Sat"," 1"," 2"," 3"," 4"," 5"," 6"," 7"," 8"," 9","10","11","12","13","14","15","16","17","18","19","20","21","22","23","24","25","26","27","28") length 3
Dim dy,mdow$(7) =("SUN","MON","TUE","WED","THR","FRI","SAT") length 3
'relay hardware pins and vars
Dim rstat(4) = (1,1,1,1) 'rstat stat 1=off 0=on
Dim relay(4) = (10,9,7,6) 'relay pins
Dim ry
'preset relays to off
For ry=1 To 4
' Pin(relay(ry)) = 1
' SetPin relay(ry),dout,oc
Next ry
' Flow switches
Dim FW12 = 4, FW34 = 5, P26 = 26
'flow switch status 1 = off 0 = on
' SetPin FW12, din
' SetPin FW34, din
' SetPin p26, ain
'just throw some values in them
tx=0:ty=8
itx=15:ity=16
itx2=63:ity2=64
icx=127:icy=128
row=5:srow=8:col=6
I2CScanner ' get a sub var test in here to show the locals here don't show
showvar ' but the ones here do
End
Sub clr
Print Chr$(27)+"[f" : Print Chr$(27)+"[2J"
Sub locate x,y
Print Chr$(27)+"["+Str$(X)+";"+Str$(Y)+"f";
Sub I2CScanner
Local found, i, temp
found=0
Print "I2C-Scanner from Adr. 8-119":Print:Print
For i = &h08 To &h77 ' gueltige I2C-Adressen von 8-119
I2C open 100, 1000 ' i2c enable 100kHz, 1000ms timeout
I2C read i, 0, 1, temp
' Print i;">"; MM.I2C " ";
If MM.I2C = 0 Then
Print:Print:Print "Found I2C-Address at "; i; " ("dec2hex$(i)+")"
found=1
I2C close ' i2c disable
Next i
If found = 0 Then Print:Print:Print "NO I2C-Address found!"
Function dec2hex$(number) ' used by I2C-Scanner
dec2hex$ = "&H"+ Hex$(number)
End Function
Sub showvar
Local g,n,p,ascii$,last=137
For g=0 To 63 'look through upto 64 variables
ascii$=""
For n = 0 To 31
p=Peek(VARTBL,n+g*64)
If p=0 Then Exit For 'build variable name (end at chr$(0))
Select Case Chr$(p)
Case "A" To "Z","0" To "9"
ascii$=ascii$+Chr$(p)
End Select
Next n
Print Str$(g,2);" ";ascii$;" ",
Print Hex$(Peek(VARTBL,32+g*64),2);" "; ' type 1 is number 2 is string not sure what anything else is
Print Hex$(Peek(VARTBL,33+g*64),2);" "; ' level sub / func ????
Print Hex$(Peek(VARTBL,35+g*64),2);Hex$(Peek(VARTBL,34+g*64),2);" "; ' looks like 8 levels of dimensions
Print Hex$(Peek(VARTBL,37+g*64),2);Hex$(Peek(VARTBL,36+g*64),2);" "; ' seems I can only use the 7 them ??
Print Hex$(Peek(VARTBL,39+g*64),2);Hex$(Peek(VARTBL,38+g*64),2);" ";
Print Hex$(Peek(VARTBL,41+g*64),2);Hex$(Peek(VARTBL,40+g*64),2);" ";
Print Hex$(Peek(VARTBL,43+g*64),2);Hex$(Peek(VARTBL,42+g*64),2);" ";
Print Hex$(Peek(VARTBL,45+g*64),2);Hex$(Peek(VARTBL,44+g*64),2);" ";
Print Hex$(Peek(VARTBL,47+g*64),2);Hex$(Peek(VARTBL,46+g*64),2);" ";
Print Hex$(Peek(VARTBL,49+g*64),2);Hex$(Peek(VARTBL,48+g*64),2);" ";
Print Hex$(Peek(VARTBL,50+g*64),2);" "; ' size ??
For n=51 To 55
Print Hex$(Peek(VARTBL,n+g*64),2);" ";
Next n
Print " ";
Print Hex$(Peek(VARTBL,59+g*64),2);Hex$(Peek(VARTBL,58+g*64),2);
Print Hex$(Peek(VARTBL,57+g*64),2);Hex$(Peek(VARTBL,56+g*64),2);" ";' little e address and/or ????
For n=60 To 63
Next n
Print
If ascii$="LAST" Then Exit For
Next g
Print "test ";Hex$(Peek(VARADDR test()))
Print "fn ";Hex$(Peek(VARADDR fn))
Print "r$ ";Hex$(Peek(VARADDR r$()))
Print "rstat ";Hex$(Peek(VARADDR rstat()))
Print "relay ";Hex$(Peek(VARADDR relay()))
Print "last ";Hex$(Peek(VARADDR last))
Can any one help with the vartable structure.
Quazee
Quazee137
Posted: 03:16am 06 Jul 2018
OK here is the first part of my adventure with the FRAM
Getting the variable names passed to function
Print "1st part testing of varf concept "
Print " This part extracts the variable names to be use in the 2nd part."
Print " This is raw not cleaned up, just working concept"
Print " Code segments are from code by TassyJim, twofingers, Centrex"
Print " And many others on TBS. Thanks to every one!"
Print
Dim x As integer
'Im cheating here. As type is in the vartable already so no need to use
' or parse it here. But! may be better for code documentation if it is.
' could just strip them out before hand.
x= VARFS("a1,b,c,d4,e5,cats,z33,apples,b3,j,tbs,k")
Print x
' V
x=VARFS("a1,b,c,d4,e5,c-ats,z33,apples,b3,j,tbs,k")
Print x
' V
x=VARFS("a1,b,c,d4,e5,cats,z33,{apples,b3,j,tbs,k")
Print x
' V
x= VARFS("a1,b,c?,d4,e5,cats,z33,apples,b3,j,tbs,k")
Print x
' V
x=VARFS("a1,b,c,d4,e5,cats,z33,apples,b3,9j,tbs,k")
Print x
' V V
x=VARFS("a1,b,c,d4,e5,cats,z33,apples,b,j,tbs,k")
Print x
Print varfs("A,big,THANKS,to,all,at,the,back,shed")
Print "-----------------------------------------"
Function VARFS(a$)
Local INTEGER z,n,m,e
a$=UCase$(a$) ' the names in vartable are UPPER CASED
e=0
For z=1 To Len(a$)
If Mid$(a$,z,1)="," Then z=z+1
If Mid$(a$,z,1)< "0" Then e=1
If Mid$(a$,z,1)> "Z" Then e=2
If Mid$(a$,z,1)> "9" And Mid$(a$,z,1)<"A" Then e=3
Next z
If e<>0 Then
VARFS=e
Exit Function
End If
On ERROR SKIP 1' if SP$ doesn't exist, next line will cause an error
Erase SP$
z=1:n=0
Do 'count instances of delimiter for DIM SP$()
z=Instr(z,a$,",")
If z=0 Then
Exit Do
End If
n=n+1:z=z+1
m=n+1:n=1
Dim SP$(m)
z=Instr(1,a$,",")
If z=0 Then SP$(m)=a$:Exit Do
SP$(n)=Left$(a$,z-1):a$=Mid$(a$,z+1)
e=Instr(1,"0123456789",Left$(sp$(n),1)) ' can't start with number
If e<>0 Then
VARFS=4
Exit Function
End If
n=n+1
For z=1 To m ' all var names are exclusve.
For n=1 To m
If z=n Then Exit For
If sp$(n)=sp$(z) Then e=5
Next n
Next z
If e<>0 Then
VARFS=e
Exit Function
End If
'testing to show sp$()
For z=1 To m
Print sp$(z);" ";
Next z
Print
End Function
Working on a fram hex editor for testing
and playing with the vartable dump test.
I have 8K,32K and 64K byte chips on RTC modules
the 128K is on the way.
