Local Time 08:47 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Settick start timing
expo
Posted: 04:01am 21 May 2018
Can someone tell me when "Settick" starts? Is it at the start of the programme, the line position in the programme or, in the case of a subroutine, when the line in the subroutine starts?
Thanks,
expo
Posted: 04:53am 21 May 2018
  expo said   Can someone tell me when "Settick" starts? Is it at the start of the programme, the line position in the programme or, in the case of a subroutine, when the line in the subroutine starts?
Thanks,
expo
It's at the point in your program where you set it.
You could test this to satisfy your curiosity, by printing out the TIMER, using SETTICK and then in your sub, have it print out the TIMER again. Put a tight DO:LOOP after the settick line so your cpu is just spinning doing nothing.
Subtract one number from the other and you should get the time in your SETTICK + a few for the processing and serial comms.
expo
Posted: 05:09am 21 May 2018
thanks capt for your early morning reply.....
expo
Posted: 05:35am 21 May 2018
Often I want the first tick subroutine to occur immediately, rather than wait for a long time for the first timed event.
In those cases, I set the timer then immediately call the SUB
SETTICK 10000, doread "do a reading every 10 seconds
doread ' do the first read 'NOW'
expo
Posted: 05:48am 21 May 2018
Thanks Jim, good suggestion.
expo
Posted: 02:41pm 21 May 2018
In JavaScript there is something called SETTIMEOUT.
It works the same as a SETTICK but it will only execute the routine one time.
Currently i simulate it like this:
[code]
SUB DoRead
SETTICK 0, 0, 1
'Do the stuff you need to do
SETTICK 10000, DoRead, 1
END SUB
[/code]
The subroutine is then more self contained as it takes care of its own invocation.
You can even in certain circumstances manipulate how long the interval is.
[code]
SUB DoRead
STATIC INTEGER Interval
SETTICK 0, 0, 1
if Condition1 = true then Interval = 5000 else Interval = 10000
SETTICK Interval, DoRead, 1
END SUB
[/code]
You start the whole thing by just calling it one time. You could add a parameter to control the stop and start of it
[code]
SUB DoRead(Action)
SETTICK 0, 0, 1
IF Action = "STOP" THEN
EXIT SUB
ENDIF
END SUB
[/code]
You can add more 'Actions' if needed. Maybe a 'Speed' setting that sets the interval to a certain value.
