Local Time 08:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interrupt Disable
panky
Posted: 11:26pm 16 May 2018
Possibly one for Geoff and/or Peter?
Is there any way currently to globally disable and enable all interrupts?
Is it something that may be possible or desireable in the future?
panky
Posted: 12:01am 17 May 2018
No, not at the moment, however it is worth consideration.
Posted: 06:22am 17 May 2018
A solution could be to add a global variable and check it in every interrupt routine.
It does not prevent the processing time that is used by the interrupts but that might be negligible.
Posted: 04:15pm 17 May 2018
  panky said   Possibly one for Geoff and/or Peter?
panky
This is something I could quite often use. Microblocks has pipped me to the post as that is the solution I use in such cases.
Would still love to see DI and EI instructions.
Edited by CaptainBoing 2018-05-19
