Local Time 06:51 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UNIX-like commands: cat dir grep more
rave
Posted: 03:35am 22 Apr 2018
Hi all,
I've uploaded my UNIX-like "implied RUN commands" to FruitOfTheShed
These commands are:
cat catenate files to output
dir list files
grep search files using a pattern or string
more file pager and hexdump utility
These commands support the following useful command-line features:
- File and directory name globbing with * and ?
- Paths can be separated with \ as usual or with /
- Input can be redirected with < FILE
- Output can be redirected with > FILE or >> FILE (append)
This works thanks to the power of MMBasic 4.5. Geoff did a great job and for MMBasic.
For example:
- Display and page through all .bas files in the project directory and its subdirectories (hit key SPACE/ENTER/ESC while viewing):
more project/*.bas project/*/*.bas
- Hexdump all .bmp files located in B:\images:
more -x B:\images\*.bmp
- Search and display the lines with line numbers of .bas files in the project directory that have the text "Usage" at the start of the line:
grep -n "^Usage:" project/*.bas
A driver program WALKDIRS.BAS is included in MMUNIX-v2.zip to implement your own UNIX-like commands. The driver program performs de-globbing and sets up file redirects. This way you only have to add a few command-related subs to perform actions on files/directories .
I've "stolen" a bit of beautiful code written by Rob Pike for regex matching with my grep implementation, but I rewrote it in MMBasic and added the [] ? + operators to make it more useful.
Enjoy!
- Rob
twofingers
Posted: 02:50pm 22 Apr 2018
Hi Rob!
Congratulation! Good job!
GREP and REGEX are a must have.
I will try later.
Kind regards
Michael
