Local Time 06:52 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : two bash scripts
Quazee137
Posted: 04:06pm 17 Apr 2018
I have been using Geany to edit my code and started thinking of
how to make use of the extra tool slots. Still reading up on that
but did get around to making these two scripts work.
xsend.sh will stop the MicroMite then send the "xmodem r"
and the using sx will send the file to the MicroMite
then send "run" and newline
xrecv.sh will stop the MicroMite then send the "xmodem s"
and the using rx will get the file from the MicroMite
then send "run" and newline. It strips any nulls at the
end of the file.
xsend.sh
#!/bin/bash
# while in file manager (nemo) I open a term
# and type in the following
# xsend.sh file2send port (ttyACMx ttyUSBx)
# this is raw and experimental
DEV=/dev/$2
echo $'\cc' "xmodem r" > $DEV
sleep 2
sx $1 > $DEV < $DEV
sleep 2
echo "run" $'\n' > $DEV
xrecv.sh
#!/bin/bash
# xrecv.sh file2get port (ttyACMx ttyUSBx)
DEV=/dev/$2
echo $'\cc' "xmodem s" > $DEV
sleep 2
rx $1 > $DEV < $DEV
sleep 2
sleep 2
tr < $1 -d '\000' > "tmp"
mv tmp $1
I have more I am trying to get working and will post as I get them
to "KISS" mode. There are a few python scripts "Find_ports.py -l"
and miniterm.py it defaults to 9600 a ^T b 38400. Playing with it to
learn python. A quick way to do some input after xsend is to use
screen /dev/ttyACM0 38400 it also useful to edit.
Hope some can make use of these.
Quazee
