Forum Index : Microcontroller and PC projects : LOCAL problem.....
Hi all. ![]() QUESTION: With the LOCAL command for use in Sub's, can different subs have different LOCAL commands with the same variable name? I thought you could, but it it throwing a wobbly when I try: I am getting 'E already declared.' errors. As one sub calls the other, D$ is throwing an error, but I figured you could have LOCAL D$,E$ in one Sub, and another LOCAL D$,E$ in another sub and it would not care - as they are local to the sub they are defined in, and vanish into the great RAM monster in the sky when the Sub ends. Do I actually have that wrong? If I change the string names to something else, no problem, so that is the workaround I am using for now. Smoke makes things work. When the smoke gets out, it stops! |
That's a bit Strange Grog, I'd expect you could & this little bit of code works in DOS. Phil. |
This works too, when Sub2 is called while still in Sub1. Edit:- Still works if I call Sub2 before the NEXT N in Sub1 also. |
| Azure Guru Joined: 09/11/2017 Location: AustraliaPosts: 446 |
You are using E$ as the passed argument and a local variable. |
OH !!!!!!!!How the hell did I miss that, for God's sake.......(rhetorical!) All fixed. Feeling a little silly now. Smoke makes things work. When the smoke gets out, it stops! |
Glad I spotted it first then. Even more happy it is all working. |
I don't think you should be using 'CONST" in a SUB/FUNCTION If it is a true CONST, it belongs in the main code with the GLOBALs If not a true CONST, use a LOCAL variable Jim VK7JH MMedit |
Was pretty easy to look straight past that. P&G Zero. Azure One. |
@ Jim - I will take your comments about CONST under advisement. Yes, I will change that. [Quote=Phil23]P&G Zero[/Quote] I see what you did there. Smoke makes things work. When the smoke gets out, it stops! |
Lets not start any scoring, I am just a newbie to the MM and grogster designs some lovely boards . |
Very kind, but Azure does get an approval tick for noticing this one! Smoke makes things work. When the smoke gets out, it stops! |
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1139 |
You're way ahead in the number of Posts count though , Mr Grogster ChopperP |
