Local Time 05:47 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Not MM but PC related
lew247
Posted: 10:23pm 13 Apr 2018
Is there anyone that can and is willing to try and explain to me how to use the Dark Sky API?
Their online support page here
I can't use it with an ESP8266 or similar or even a MM because there's over 30,000 characters in a reading
Sample API call if you want to see what it returns
I'm thinking about doing it in a web page type app or does anyone have any ideas how to download it ready to use the MM to display what's returned?
I found This which seems to be some way of parsing it on a web page on a server which I could use (if I knew how)
I can't make head nor tail of the instructions on the page
It's not written for people that's unfamiliar with it
Posted: 07:40am 14 Apr 2018
I would advise to not go this way.
It will add a point of failure which is not under your control.
An ESP should have about 80Kb of working RAM. Not sure how much of that is left after loading a program.
Unfortunately JSON is very verbose. A CSV output would use probably only 20% of the amount of data.
