Local Time 04:42 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reading Modbus Energy Meter.
Phil23
Posted: 06:40am 07 Apr 2018
Thought I'd start a new thread, not really appropriate to tag it on the end of Modbus CRC.
Ok, So I now have this mess of workings and it is returning a result.
Just using a hard coded string to request a voltage reading from the meter on address 002.
Just not sure if I'm going around in circles converting data from one form to another un-necessarily.
Any feedback would be greatly appreciated.
  Quote   volts$ = CHR$(02)+CHR$(04)+CHR$(0)+CHR$(0)+CHR$(0)+CHR$(02)+CHR$(&h71)+CHR$(&hF8)
Dim String DataStr
print volts$
Open "Com1:9600,,RecComs,8" as #1
print #1, volts$;
Do While Inkey$="": Loop
' Pause 1000
Sub RecComs
print "In Coms Sub"
Local Integer BufLen
'BufLen=LOC(#1)
print BufLen 'Local String DataStr
'If LOC(#1)>8 then 'If COM1 serial port buffer is NOT empty.... Was 100
Do While BufLen<> LOC(#1)
BufLen=
LOC(#1)
PAUSE 50
'End if
DataStr=
INPUT$(LOC(#1),#1) 'then suck everything in the buffer out and stick it in D$....
print "Response ";DataStr
print "Voltage "; Mid$(DataStr,4,4)
print "Length "; BufLen
Response$=
For n=1 to BufLen
'Print Hex$(Asc(Mid$(DataStr,n,1)),2)
Response$=Response$+Hex$(Asc(Mid$(DataStr,n,1)),2)
Next n
print Response$
IEEE754
Sub IEEE754
ReadingStr$=
"&H"+Mid$(Response$, 7,8)
print ReadingStr$
Reading%=
Val(ReadingStr$)
Sign%=Reading% >>
31 'Read the Sign Bit
Expo%=((Reading% >> 23) And &hff) - 127 'Extract Exponent, Remove sign, Subtract Offset
Ans!=((Reading% Or &h800000) And &hffffff)/2^(23-Expo%)*(-1)^Sign% 'Extract Mantissa & Add implied 24th bit, Shift Point in Binary & apply sign
print "Text Input String: ";ReadingStr$
print "Hex Value Reading: ";Hex$(Reading%,8) 'Reading in Hex
print "Binary Value: ";Bin$(Reading%,32) 'Reading in Binary
print "Sign Bit: ";Hex$(Sign%)
print "Exponent & -offset: ";Bin$(Expo%+127,8), Str$(Expo%)
print "Mantissa Value: ";Bin$((Reading% Or &h800000) And &hffffff,32)
print
print "Returned Value: ";Str$(Ans!,10,1)
print
Bit I have trouble getting my head around is that the "String" that comes in the com port is really a series of bytes & how I should treat them.
Phil.
Posted: 07:11am 07 Apr 2018
A 'string' is only a collection of bytes. In MMBasic, strings can contain any byte value from zero to 255. Internally MMBasic doesn't care.
The only difficulty is PRINTing the string that contains non-printable characters.
You have solved that by converting to HEX for viewing but that's only for your benefit, not the program.
Internally you can stick to strings for storage without any concern.
Phil23
Posted: 08:58am 07 Apr 2018
  TassyJim said  You have solved that by converting to HEX for viewing but that's only for your benefit, not the program.
Rather Excited that I can now read Volts!
Next step is to read the whole damn meter.
(And the other two).
Phil.
Posted: 10:02am 07 Apr 2018
Small point and would only go wrong rarely, but after you suck in the chars you could have more than BufLen.
Best to set BufLen = len(DataStr)
to be sure.
On a style point, using globals for Response$ and so on will hurt you sooner or later. Instead, pass as a param (to IEEE754 in this case).
Also, you may as well get the byte direct from DataStr rather then re-convert from hex.
It looks odd to use a $ with Response$ but Str instead with DataStr.
I'll leave off anything about explicit typing of variables...
Phil23
Posted: 08:53pm 07 Apr 2018
All totally correct John.
What I posted above is at this stage raw workings with trial & error bits commented out.
Once I've got all the working parts doing their job I'll tidy them up into correctly written functions with better variable usage.
Phil.
