Local Time 05:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Win10 MMbasic Dos Launch.
Phil23
Posted: 09:05pm 04 Apr 2018
Hi All,
I know this is most likely a Win10 issue, not MMedit.
When I click the gear cog, it takes about 3 seconds to launch the DOS basic.
Anyone know a solution.
I know Win10 exhibits this behaviour elsewhere, like when you create say a calculator shortcut & assign Ctrl+Shft+C to it.
Hit the keys & the calculator appears about 3 seconds later.
More than slightly annoying....
Phil.
Posted: 11:36pm 04 Apr 2018
It's Windows doing a security check.
It used to be slow on the first opening then OK for the rest of the day but it seems to have got worse.
It even happens to Microsoft applications.
Someone will offer a solution - it starts with "Linux"
Phil23
Posted: 09:50am 05 Apr 2018
Hi Jim,
Yeah a Windows thing.
I lost enthusiasm about a possible solution after a bit of a look about....
https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings-winpc/3-second-delay-when-using-shortcut-key -to-launch/034a9767-60d9-47c7-a7ae-747fe7f3853a
Ctrl-Shft-C Calculator
Ctrl-Shft-S Snippy Tool
Ctrl-Shft-N NotePad++
Ctrl-Shft-T Teraterm
Ctrl-Shft-D Device Manager
They all jump up instantly on my Win7P PC.
Setup the same on Win10 & it's wait 3 seconds.
Phil.
BrianP
Posted: 11:28pm 08 Apr 2018
Hi Phil
You need to open Windows Defender & put in an exclusion for Dos MMbasic. I had exactly this issue (mine took 20 seconds to open) & now opens instantly.
Oh the joys of living with Microsoft...
Brian P
