Local Time 02:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RBOX error
lew247
Posted: 02:29pm 11 Mar 2018
I'm trying to draw several boxes on the screen 7" SSD1963 & an E100 and I'm getting a weird error
[code]
[15] RBox 400,00,401,100, RGB(200,148,77), RGB(22,20,15) ' Outdoor temp
Error: 13145165 is invalid (valid is 0 to 100)
[/code]
My code is dead simple
[code]
CLS
RBOX 00,00,400,100,10, RGB(47,40,32), RGB(12,26,8) 'time
RBOX 400,00,401,98,10, RGB(200,148,77), RGB(22,20,15) ' temp
RBOX 400,00,401,100, RGB(200,148,77), RGB(22,20,15) ' Outdoor temp[/code]
Edited by lew247 2018-03-13
Posted: 02:35pm 11 Mar 2018
Check the number of parameters in each line - compare the error line to the others
lew247
Posted: 02:41pm 11 Mar 2018
  matherp said   Check the number of parameters in each line - compare the error line to the others
I did before I posted
I never just post something without trying to figure it out myself first*
it's a 480 X 800 display so the number parameters in each line are correct
lew247
Posted: 02:42pm 11 Mar 2018
oh I'm such an idiot I see it now
In case any other people who are new to this come across the same problem it was [code] RBOX 400,100,401,98,10, RGB(200,148,77), RGB(22,20,15)[/code]
The 2nd digit is the one to move the box down the screen I'd forgotten to change it
and while this is laughable for you experienced people it's dead simple for someone "newish" to do
Posted: 08:40pm 11 Mar 2018
Overwriting one element with another, while of little use, does not always cause an error.
I would have thought that the problem was on the line for outdoor temperature.
You missed the value for 'roundness' which can only be between 0 and 100
Because it was missing, the next value was used. The next value is the colour RGB(200,148,77) which evaluates to 13145165.
The error message was correct even though sometimes it takes a while to work out what the error message really means.
