Local Time 14:26 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Testing my keyboard function
Quazee137
Posted: 05:48am 06 Mar 2018
I did this as it works as is on all the LCDs I have 2.4, 2.8, 3.5, 4.0
puts it in the upper left of the larger displays. Sill raw but felt
with all those here have shared. my little bit back.
Option base 1
PWM 2, 250,20 ' back light to 25%
SetPin 15, intl,touched
SetPin 15, inth,untouched
Colour RGB(blue), RGB(yellow)
Dim key$(45)=("1","2","3","4","5","6","7","8","9","0",".","q","w","e","r","t",
"y","u","i","o","p","*","a","s","d","f","g","h","j","k","l",":","/","z","x","c",
"v","b","n","m","#","%","^","^"," ") length 1
Font 1,2
main do
CLS
Text 10,100,"Touch Screen",,1,3
Pause 100
Do:Loop Until pendown
myt$=keybd$("A mix of Text")
Loop Until myt$<>""
myw$=keybd$("7 day or 28 day")
Loop Until myw$="7" Or myw$="28"
myf$=keybd$("Use Flow switch y/n")
Loop Until myf$="y" Or myf$="n"
myr$=keybd$("relay 1 to 4")
Loop Until Instr( 1,"1234",myr$)<>0
myd$=keybd$("Duration 000 to 999")
Loop Until (Len(myd$)=3 And isnum(Mid$(myd$,1,1)) And isnum(Mid$(myd$,2,1))
And isnum(Mid$(myd$,3,1)))
mys$=keybd$("00:00 to 23:59")
Loop Until validtime(mys$)
CLS
Text 0,25,myt$
Text 0,50,myw$
Text 0,75,myf$
Text 0,100,myr$
Text 0,125,myd$
Text 0,150,mys$
Text 0,200,"Touch Screen to Continue",,1,1
Loop '
main loopFunction validtime(t$)
validtime=0
If Len(t$)<>5 And Mid$(t$,3,1)=":" Then Exit Function
If Not(isnum(Mid$(t$,5,1))) Then Exit Function '0...9
If Not(Instr(1,"012345",Mid$(t$,4,1))) Then Exit Function '0...5
If Not(Instr(1,"012",Mid$(t$,1,1))) Then Exit Function ' 0..2
If Mid$(t$,1,1)="2" And Not(Instr(1,"0123",Mid$(t$,2,1))) Then Exit Function
'0..3
If Instr(1,"01",t$) And Not(isnum(Mid$(t$,2,1))) Then Exit Function
validtime=1
End Function
Function isnum(n$)
isnum = Instr(1,"0123456789",n$)>0
End Function
Sub touched
tx=Touch(x):ty=Touch(y)
If tx=-1 Then Exit Sub
If ty=-1 Then Exit Sub
itx=(tx\29):ity=(ty\34)
PenDown=1:penup=0
Sub untouched
PenDown=0:penup=1
Function keybd$(msg As string) As string
kbuff$=""
CLS RGB(blue)
RBox
Text
RBox
Text
0,1, 319, 33,6,RGB(yellow),RGB(blue)
6,2,msg$,l,,,RGB(yellow),RGB(blue)
0,34, 319, 33,6,RGB(black),RGB(yellow)
6,35,kbuff$+" ",l,,,RGB(black),RGB(yellow)
idx=1
For y=2 To 5:For x=0 To 10
RBox x*29,y*34, 29, 34,6,RGB(black),RGB(yellow)
Text x*29+7,y*34+3,key$(idx),,,,RGB(blue),RGB(yellow)
idx=idx+1
Next x:Next y
Text 305,118,"Bs",cm,,1,RGB(blue),RGB(yellow) 'small Bs text
RBox 261,170,58,34,6,RGB(black),RGB(yellow)
' Shift box
Text 290,185,"Shift",cm,,1,RGB(blue),RGB(yellow)
RBox 0,6*34, 319, 34,20,RGB(black),RGB(yellow) 'space bar
'will need to set timmer so no touch in say 50 sec's we exit/err/restart pgm
Do While penup: Loop ' look for touch
Do While pendown:Loop ' look for no touchPause 50
idx=1 'index into char array
Select Case ity ' extract line touched
Case 0,1
keybd$ = kbuff$ 'touching upper text area is EnterKey
Exit Function
Case 2
idx = idx+itx '1st row of keys
Case 3
idx = idx+itx+11 '2nd
Case 4
idx = idx+itx+22 '3rd
Case 5
idx = idx+itx+33 '4th
Case 6
idx=45 'spacebar
End Select
k$=key$(idx)
Select Case key$(idx)
Case "a" To "z" ' shiftables
If sf=32 Then
k$=Chr$(Asc(k$)-sf)
sf=0
If Len(kbuff$) =<15 Then kbuff$=kbuff$+k$
Case "0" To "9",".","#","%",":","/"," " 'last part customize by need
Case "^"
sf=32
' shift flag
Case "*" ' backspace
If Len(kbuff$) >1 Then
kbuff$=Left$(kbuff$,Len(kbuff$)-1)
ElseIf Len(kbuff$)=1 Then
kbuff$=""
End Select
End Function
here is a zipped pdf. how do we add pdf's here?
2018-03-06_154751_kf-test.pdf.zip
Edited by Quazee137 2018-03-07
Frank N. Furter
Posted: 08:29pm 06 Mar 2018
thanks for sharing!
I have a Backpack170 from Bigmick. Can you tell me what I need to set so that it works with this board?
I used:
OPTION LCDPANEL ILI9341,L,4,5,6
OPTION TOUCH 7,2
GUI CALIBRATE
Calibration was ok.
I can read "Touch Screen" on my display and that's it...
EDIT: I used MM.VER 5.0408 with a 2.4" display...
FrankEdited by Frank N. Furter 2018-03-08
Quazee137
Posted: 04:27am 07 Mar 2018
change
to
SetPin 7, intl,touched
SetPin 7, inth,untouched
should do it.
The testing code is by my Granddaughter. Every now and then she likes
to tinker with the mite here.
GoodToGo!
Posted: 07:25am 07 Mar 2018
Looks good Quazee!
I had to change a couple of lines to get it to run on my Explore100 but it works nicely. See below:-
Option base 1
'PWM 2, 250,20 ' back light to 25% '(Not required on Explore 100)
'SetPin 15, intl,touched '(Not required on Explore 100)
'SetPin 15, inth,untouched '(Not required on Explore 100)
gui interrupt touched, untouched 'For MM+ (tested on Explore 100)
Dim key$(45)=("1","2","3","4","5","6","7","8","9","0",".","q","w","e","r","t","y","u","i","o","p","*","a","s","d","f","g","h ","j","k","l",":","/","z","x","c","v","b","n","m","#","%","^","^"," ") length 1
Font 1,2
Do ' main do
CLS
Pause 100
Loop Until myt$<>""
Loop Until (Len(myd$)=3 And isnum(Mid$(myd$,1,1)) And isnum(Mid$(myd$,2,1)) And isnum(Mid$(myd$,3,1)))
CLS
runText 0,25,myt$
Text 0,50,myw$
Text 0,75,myf$
Text 0,100,myr$
Text 0,125,myd$
Text 0,150,mys$
Loop ' main loop
validtime=0
If Mid$(t$,1,1)="2" And Not(Instr(1,"0123",Mid$(t$,2,1))) Then Exit Function '0..3
validtime=1
End Function
Function isnum(n$)
End Function
Sub touched
PenDown=1:penup=0
Sub untouched
PenDown=0:penup=1
kbuff$=""
CLS RGB(blue)
RBox 0,1, 319, 33,6,RGB(yellow),RGB(blue)
Text 6,2,msg$,l,,,RGB(yellow),RGB(blue)
RBox 0,34, 319, 33,6,RGB(black),RGB(yellow)
Text 6,35,kbuff$+" ",l,,,RGB(black),RGB(yellow)
idx=1
idx=idx+1
Next x:Next y
RBox 261,170,58,34,6,RGB(black),RGB(yellow) ' Shift box
'will need to set timer so no touch in say 50 sec's we exit/err/restart pgm
Pause 50
Case 0,1
Exit Function
Case 2 '1st row of keys
idx = idx+itx
Case 3 '2nd
idx = idx+itx+11
Case 4 '3rd
idx = idx+itx+22
Case 5 '4th
idx = idx+itx+33
Case 6 'spacebar
idx=45
End Select
k$=key$(idx)
If sf=32 Then
k$=Chr$(Asc(k$)-sf)
sf=0
Case "^" ' shift flag
sf=32
kbuff$=""
End Select
End Function
Cheers!
GTG!
Frank N. Furter
Posted: 08:02am 07 Mar 2018
Hi Quazee137,
thanks for your response!
I tried
before, but I get an error:
[5] SetPin 7, intl,touched
Error: Pin 7 is reserved on startup
Frank
Quazee137
Posted: 08:54am 07 Mar 2018
Hi Frank
My backpack from Bigmick is setup like this
OPTION LCDPANEL ILI9341, LANDSCAPE, 4, 5, 6
OPTION TOUCH 7, 2
this will do it
SetPin 2, intl,touched
SetPin 2, inth,untouched
Quazee
Frank N. Furter
Posted: 11:01am 07 Mar 2018
Hi Quazee,
thank you very much! Now it works!
Frank
SteveA
Posted: 11:52am 07 Mar 2018
Very cool, to get it running on MM+ using the Silicon Chip Explore 64 PCB change the first few lines to:
Option base 1
PWM 2, 1000, 50 ' back light
GUI INTERRUPT touched, untouched
Font 1,2
For some reason MMedit doesn't like key$ split over several lines, I can't see any hidden control characters, so I don't know why. But making it one long line works!
Quazee137
Posted: 07:21pm 07 Mar 2018
Hi Frank
Glad it works.
Yes Steve the key$ is one long line.
Quazee
Quazee137
Posted: 10:59am 03 Aug 2018
While exploring the vartable I found that I was using the "length" wrong
so here's an update of the keyboard function test code.
Having length work as it should makes a big deference ram usage.
with out length 1 or using it wrong
> memory
Flash:
4K ( 5%) Program (159 lines)
56K (95%) Free
RAM:
11K (22%) 2 Variables
0K ( 0%) General
39K (78%) Free
with length 1 and using it right
> memory
Flash:
56K (95%) Free
RAM:
1K ( 1%) 2 Variables
0K ( 0%) General
49K (99%) Free
Print MM.Ver,MM.Device$
Print "keyboard-function-12-07-2018.bas"
' fixed the "length" to the right usage, before initialising key$ array
Option base 1
'use your touch interrupt pin ----
SetPin 2, intl,touched '<-- here
SetPin 2, inth,untouched '<-- here
'gui interrupt touched, untouched
'For MM+ (tested on Explore 100) Thanks GoodToGo!
' (tested on Explore 64 PCB) Thanks SteveA
Dim key$(45) length 1 = ("1","2","3","4","5","6","7","8","9","0",".","q","w","e","r","t","y","u","i","o","p","*","a","s","d","f","g","h","j","k" ,"l",":","/","z","x","c","v","b","n","m","#","%","^","^"," ")
Font 1,2
Do ' main do
CLS
Pause 100
Loop Until myt$<>""
myf$=UCase$(keybd$("Use Flow switch Y/N"))
Loop Until myf$="Y" Or myf$="N"
CLS
Text 0,25,myt$
Text 0,50,myw$
Text 0,75,myf$
Text 0,100,myr$
Text 0,125,myd$
Text 0,150,mys$
Loop ' main loop
validtime=0
validtime=1
End Function
Function isnum(n$)
End Function
Sub touched
PenDown=1:PenUp=0
Sub untouched
PenDown=0:PenUp=1
kbuff$=""
CLS RGB(blue)
idx=1
idx=idx+1
Next x:Next y
'will need to set timmer so no touch in say 50 sec's we exit function
Pause 50
Case 0,1
Exit Function
idx = idx+itx
Case 3 '2nd
idx = idx+itx+11
Case 4 '3rd
idx = idx+itx+22
Case 5 '4th
idx = idx+itx+33
Case 6 'spacebar
idx=45
End Select
k$=key$(idx)
If sf=32 Then
k$=Chr$(Asc(k$)-sf)
sf=0
sf=32
kbuff$=""
End Select
End Function
Edited by Quazee137 2018-08-04
