Local Time 02:47 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unexpected text
Lee3
Posted: 01:36am 05 Mar 2018
I can't work out what is happening here.....
I've rebuilt a board for my garage door sensor project, and before I even enter much code am getting a frustrating error:
[1] SetPin 2,intl,button
Error: Unexpected text
This is the code.....
SetPin 14,dout
SetPin 25,dout
Sub button
Pulse 25,1000
Pulse 14,1000
Any interrupt code I try and use returns this error.....
I can make the pin a digital input and it works ok.
This is a micromite 4.6 Beta 1 if that is important.....
Posted: 01:56am 05 Mar 2018
That should work OK.
"Error: Unexpected text" means that the interpreter ran into something in the command that should not be there. Perhaps you have some control characters embedded in there that is throwing it off.
The other point is that 4.6 Beta 1 was in the very early days of the MX170 Micromites and it had a lot of bugs. I cannot recall if one of the bugs affected interrupts but it is very possible.
Lee3
Posted: 02:05am 05 Mar 2018
I was just wondering that, about the beta status.... I'll clear out the editor and start again, if that doesn't work it sounds like I need to start desoldering a chip..... :(
Posted: 02:09am 05 Mar 2018
  Lee3 said   it sounds like I need to start desoldering a chip..... :(
Why?
It is usually easy enough to flash the chip while in-circuit.
Lee3
Posted: 02:46am 05 Mar 2018
I have no doubt.... if you have a 'flasher'....
Lee3
Posted: 04:12am 05 Mar 2018
Must have been a beta bug or something similar..... I desoldered it and dropped in a 4.5D chip I had, works perfectly.....
palcal
Posted: 04:13am 05 Mar 2018
@ Lee3
Have a look at the Microbridge on Geoff's web page. If you cant build one yourself I'm sure someone will help you out.
Paul.
Lee3
Posted: 06:09am 05 Mar 2018
Thanks, I’ll certainly look into it, it doesn’t look too tricky...
Posted: 06:13am 05 Mar 2018
ALWAYS design the ICSP into your boards.
Either that, or include the 1455 'MicroBridge' circuit as standard.
One or the other, otherwise you cannot update the firmware in-circuit as you have found out. Edited by Grogster 2018-03-06
Lee3
Posted: 07:36am 05 Mar 2018
Or, failing that, use a socket rather than directly solder the chip.....
Posted: 07:42am 05 Mar 2018
There's no problem with directly soldering.
All the SMD versions HAVE to be, really. Take the SSOP version.
The trick is to ensure you leave an ICSP header, or if not that, then the 1455 interface so that you can update MMBASIC via USB.
You obviously were able to replace the chip, so good on you.
Lee3
Posted: 07:52am 05 Mar 2018
I must admit, I wasn't looking forward to removing the chip, but my spring loaded solder sucker did the job brilliantly. Didn't need *that* much force to pull it out afterwards.... :)
I'm looking into chip reprogramming now.... I'll have to add that to the repertoire.....
Posted: 02:05pm 05 Mar 2018
you might like to have a look at the 'constructor guide' here:
http://www.thebackshed.com/docregister/ViewDoc.asp?DocID=19
it is the most basic/cheap pic32 programmer, an arduino nano + half a dozen parts that can be bought on ebay china for just a few dollars landed.
rob :-)Edited by robert.rozee 2018-03-07
viscomjim
Posted: 04:14pm 05 Mar 2018
or have a look at this.... Pretty cool stuff on his website as far as chip, programmers and SPEED!
Posted: 04:34pm 05 Mar 2018
  viscomjim said   or have a look at this.... Pretty cool stuff on his website as far as chip, programmers and SPEED!
It's essentially the same as the 1455 mentioned already except it's remarkably expensive whereas the 1455 is almost free.
Lee3
Posted: 01:06am 07 Mar 2018
I've opted for the easy path at this stage, and ordered a Microbridge kit from Silicon Chip.... Thanks for everyone's replies...
palcal
Posted: 04:00am 07 Mar 2018
@ Lee3
When you have the Microbridge up and running download Robert Rozee's 'Picprog GUI' either from SC or RictechNZ which is Grogster's site. It makes flashing the chip a breeze. Thanks robert.rozee for making things so simple.
Paul.
Lee3
Posted: 04:09am 07 Mar 2018
I use a Mac, so it probably won't be as simple.... There does seem to be ports for pic32prog around, I just need to work out what I need first!
palcal
Posted: 04:48am 07 Mar 2018
I suppose Mac's have their drawbacks but at least you don't have to put up with Win10
Paul.
