Local Time 01:47 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VGA TFT Display for CMM???
Frank N. Furter
Posted: 09:28am 27 Feb 2018
I have a question for our display specialists. I would like to connect a THG057VGLAC-H000 with RGB-TTL to a CMM or our ASCII VT100. How could I generate the pixel clock? Do you think this will work? I have some doubts about the timing - otherwise it would have to work just to put all R, G and B bits together at the respective outputs?
... or does anyone of you know a chip (or board) that converts analog VGA to TTL-VGA?
THANKS!!!
Frank
Posted: 10:04am 27 Feb 2018
http://geoffg.net/tft-maximite.html
https://github.com/heise/MAXIMITE
Google "Maximite TFT" for more results.
Frank N. Furter
Posted: 10:54am 27 Feb 2018
Hi MicroBlocks,
thanks for your response - I know the TFT Maximite from MAKE. But this works only with a modified firmware! I'd rather put it in hardware and install a non-modified ASCII VT100 or MMC...
Frank
Posted: 11:38am 27 Feb 2018
It is strange that they call it a 'VGA' when there is no VGA connection available.
What you could do is just connect the RGB outputs from the CMM to the screen as is shown in the schematic of the TFT version of the CMM (each color to the 8 corresponding pins on the display). If the timing is the same as a VGA then it should work.
If not, then you have to modify a lot more.
Posted: 12:01pm 27 Feb 2018
  Quote  How could I generate the pixel clock?
The pixel clock can be taken from the SPI CLK output of the PIC. The issue I can't comment on is how this works with the CMM which doesn't put out 640 pixels across the screen. On the MMX it would work although you may have to gate the clock with the line and frame blanking to avoid clock pulses when you don't want them
Frank N. Furter
Posted: 08:13am 28 Feb 2018
Thanks for your advice - I'll give it a try.
Frank
