Local Time 01:49 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Too many SUB and FUN
Lee3
Posted: 07:45am 26 Feb 2018
I have been getting this error today.... My program is basically three subroutines, two of which loop depending on the input of a distance sensor. The program is a garage-door open sensor/alert.
I seem to have exceeded some limit... but I don't know what/where?
Please excuse the code, it is pretty clunky I'm sure, but it was tinkered up from scratch. It does work, the error is intermittent, which makes it more frustrating.....
The error:
[15] If d>25 Then doorclosed
Error: Too many SUB and FUN
Here is the code....
SetPin 25,dout
SetPin 26,dout
SetPin 17,dout
doorclosed
Sub dooropen
time=time+1
Print "door open " time
d = Distance(15,16)
Pause 1000
If time=3 Then alert
Sub alert
Pulse 17,buzz*50
time=0
buzz=buzz+1
dooropen
Sub doorclosed
time=0
buzz=1
d = Distance(15,16)
Pause 200
If d<25 Then dooropen
Print "checking"
Pause 200
Posted: 08:34am 26 Feb 2018
You are calling dooropen from within doorclosed and visa versa so depending on the data this will create an avalanche of calls one to the other which will create the error (distance varying about 25). Also dooropen can be called from within itself via alert.
Suggest you put some more hysteresis in the code "distance>40" "distance<10" or similarEdited by matherp 2018-02-27
Lee3
Posted: 10:07am 26 Feb 2018
Thanks very much for the reply.
I've discarded the doorclosed sub, and just have that code as the main body. I'll take the dooropen call out of alert also, as it seems redundant in any case.... I was planning on working out some hysteresis when the sensor was installed in place over the door and better measurements made.... Cheers... Lee
Azure
Posted: 10:32am 26 Feb 2018
As well as what matherp suggested your dooropen is a continuous loop.
So once you call dooropen it will nest to a door closed as another level within the dooropen loop. This is what is causing your error. The dooropen never returns.
As a tip to check where your error is add a print at the start and end of each sub
[code]Sub dooropen
Print "entering dooropen"
Print "exiting dooropen"
Sub alert
Print "entering alert"
Print "exiting alert"
Sub doorclosed
Print "entering doorclosed"
Print "exiting doorclosed"
[/code]
Your code would probably work better with one distance call in a main loop and then based on the distance and whether it was previously open or closed choose to call dooropen or doorclose.
Lee3
Posted: 11:07am 26 Feb 2018
Thanks - I think its working fine now - I removed the call to doorclosed from dooropen, and changed it to EXIT SUB. Now I just need to wire up a second sensor for the second door, and try and incorporate a 'silence' alarm for when I work in the garage....
SetPin 25,dout
SetPin 26,dout
SetPin 17,dout
Sub dooropen
time=time+1
d = Distance(15,16)
Print d
Pulse 26,50
Pause 1000
If d>25 Then Exit Sub
Sub alert
Pulse 17,buzz*50
time=0
buzz=buzz+1
time=0
buzz=1
pause 1000
d = Distance(15,16)
Print "checking"
Pulse 25,30
Posted: 09:18pm 26 Feb 2018
Nice you got it sorted.
Generally speaking, I try to avoid calling one sub from within another.
I call one sub from the main loop of code, then analyse the results from it in the main code when the sub returns. This is just me, others may say it's fine to call subs from within subs, but it makes it really hard to debug - as you have found out.
Paul_L
Posted: 08:01am 27 Feb 2018
@Lee3 -- Extemporaneous, convoluted, hidden logic should be relegated to deliberate attempts to obfuscate prose, not code. Use standard formatting to make the flow obvious, and add lots of comments. Forget about attempting to duplicate reverse polish notation, leave that to us Polacks. TassyJims excellent MMBasic editor MMEDIT will do the formatting for you. It might be a good idea to capitalize language defined commands and make all your variables lower case or find some other way to identify them.
Pavel Artur Jan Waclaw Lepkowski in NY
' this program is named XYZ.BAS by Lee3 on 2/26/18
' explain what the program does at the start
' formatting the code something like this helps
' stick logically connected commands on the same line
' add lots of comments, when you look at the code next year they will help
' keep the mainline in one place
MainLineBegin: ' an unnecessary label marks the mainline and makes the automatic indenting consistent
SetPin 25,dout : SetPin 26,dout : SetPin 17,dout
time=0 : buzz=1 : pause 1000
d = Distance(15,16) : If d<25 Then dooropen
Print "checking" : Pulse 25,30
END ' a redundant END, the interpreter would have ended when it reached the SUB dooropen in three more lines
MainLineEnd: ' another unnecessary label which helps preserve automatic indenting
Sub dooropen ' this opens the door and tests for d>25 which makes noise and returns
time=time+1 : Print "door open " time
d = Distance(15,16) : Print d
Pulse 26,50 : Pause 1000
If d>25 Then Exit DO ' you're really exiting the loop here, not the Sub !!!!
' it falls out of the SUB after exiting the loop here.
End Sub ' dooropen '' this tells you which sub just ended
Sub alert ' this just makes lots of noise
Pulse 17,buzz*50 : time=0 : buzz=buzz+1
End Sub 'alert
'EOF XYZ.BAS '' this assures you that the editor didn't truncate the code somehow
Edited by Paul_L 2018-02-28
Lee3
Posted: 09:27am 27 Feb 2018
Thanks for the detailed reply and lesson Paul. I'm a very much part-time coder, and this was my first hack for a few years, done in the few hours between dropping off and picking up my kids from school. The advice about exiting the sub is much appreciated..... When I edit the code again, I'll use your advice.
I don't think MMEDIT runs on Macs, so I just use a serial port emulator and the editor on the chip.
I do prefer RPN calculators, but must say the Natural VPAM Casios are fun to use too..... :)
Paul_L
Posted: 12:03pm 27 Feb 2018
Have fun with basic Lee. I don't know anything about Macs. I generally use NotePad++ but I don't think that will run on Macs.
You'd are advised to ignore that other Polack guy who uses my login.
Paul in NY
Posted: 12:20pm 27 Feb 2018
  Lee3 said   ...this was my first hack for a few years, done in the few hours between dropping off and picking up my kids from school.
you'll be back
The on-chip editor is great but simple. If you want to use your favourite text editor, consider either the Xmodem transfer or Autosave - I use the latter most of all, just press F10 in the MM console, paste your code into the console, wait for it all to zoom up the screen then press Ctrl-Z
