Local Time 00:56 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Still propeller compatable?
gadgetjack
Posted: 10:35pm 18 Feb 2018
I ran across an old project while cleaning up my shop. It was the basic chip interfaced to a propeller chip to handle the video and sound chores. It still works ok , but has the old 4.5ver software on the mm basic chip. Will the newer versions still talk to this project? If so , I will reprogram the chip for all the new features and use this thing again.
Posted: 02:45am 19 Feb 2018
Probably your chip is a PIC32MX150F128. Later versions of MMBasic (V5 and up) require a member of the MX170 or MX470 family of chips.
So, no, you cannot load the latest on that.
Posted: 10:17am 19 Feb 2018
The MicroMite Companion that you found is compatible with both the MX150 and MX170.
Have a look at which PIC chip you have, and IF it is the MX170 then you can load the latest MMBASIC. However, if it is the MX150 then I recommend grabbing a MX170 and swapping it over. You will need to load MMBASIC onto the chip - best get a MicroBridge IF you do not have a PicKit3.
gadgetjack
Posted: 05:44pm 19 Feb 2018
I have both chips on hand , so , yes I will play some more with this. Thank you for the info.
