Local Time 04:41 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need more PWM channels on your MM?
Posted: 06:11am 06 Feb 2018
Hi folks.
While browsing around on Aliexpress for something else, I did stumble across these 16-channel PWM controller modules for $1.67 each!
I know that many members want more then the 5 channels inherent in the MM chips, and so these modules might be just what those members need.
At that price, it could hardly hurt to try them out! I have bought a couple to play with. I like that the module has a positive, ground AND pwm output pin for each of the 16 channels.
Attached is the datasheet for the PCA9685 controller chip.
2018-02-06_160749_PCA9685_16-Ch_PWM_Controller_I2C.pdf
Edited by Grogster 2018-02-07
Azure
Posted: 06:38am 06 Feb 2018
Nice find Grogster. Since they are intended as LED drivers the PWM frequency is a bit limited, just something to be mindful of depending on the intended application.
Frank N. Furter
Posted: 08:35am 06 Feb 2018
It's really a very nice chip! You can also drive 16 servos with it:
ADAFRUIT - 16-channel-pwm-servo-driver.pdf
Frank
disco4now
Posted: 07:37am 03 Apr 2018
I ordered a couple of these and some cheap servos with the idea of doing some playing with a Micromite version of the DIYODE robot thingy. I have ported the Adafruit library to run on MMBASIC so have gotten as far as driving some servos. I have not looked at the output with a scope but seems to drive the servos OK. The code below includes some routines to allow the calibration of the servos as well.
Gerry
DIYODE Robot thingy
  Quote   '------------------------------------------------------------------------------'
' Micromite library for PCA9685 '
' Uses PCA9685 16-channel PWM over I2C to support 16 Servos or PWM pins '
' Author: Disco4now TBS Forum '
dim ProgTitle$ = "PCA9685 Test Suite" '
dim ProgVer$ = "v1.0.0" '
dim ProgDate$ = "03-Apr-2018" '
'Code for a Micromite to communicate with a PCA9685 16-channel PWM over I2C.
'Also contains routine to allow calibration of servos.
'The console input is scanned and characters read as they are typed
' ServoMIN(16),ServoMAX(16) hold min and max pulse widths for 0 and 180 deg respectively.
' nominal values 800 and 2200 but adjust to suit your particular servos
' calibration values for each servo
' 0-9,a-f used to select the servo to calibrate.
' SPACEBAR sets servo near the centre i.e 90 deg for nominal range of 0-180
' right arrow sets servo to 180 deg.SPACEBAR to reurn to centre.
' PgUp/PgDn increase/decrease pulse width by 10ms. Up/Down Arrows increase/decrease by 1 ms
' Press SPACEBAR and current value will print to console.
' When the servo is operating correctly then record the max/min values and used them
' to set ServoMIN(x) and ServoMAX(x) values in the PWMInit() routine.
' nominal values 800 and 2200 but adjust to suit your servos
' e.g.
' ServoMIN(0)=480:ServoMAX(0)=2140
' ServoMIN(1)=480:ServoMAX(1)=2085
' ServoMIN(2)=460:ServoMAX(2)=2125
' Once these are set you just use
' SERVOSet(id,angle)
' to set individual servo to desired angle
Option Explicit
Option Default NONE
' Data Variables
dim integer loc0last,loc0now,loc1last,loc1now,loc2last,loc2now,GetCon=0,GetCom1=0,GetCom2=0
dim integer i,id=0,highlow=0
' Program Initialization
Print "Starting " + ProgTitle$ + ": " + ProgVer$ + " - " + ProgDate$
settick 100,IsSerialOrConsoleComplete,1
'Initialise the PCA9685 16-channel PWM over I2C at frequency of 1000
PWMInit 50 '50Hz for 20ms pulse period represented by 4096 ticks
'Uncomment to sweep servos at start up.
' for i=0 to 15
' SERVOset i,0
' pause 500
' SERVOset i,180
' pause 500
' SERVOset i,90
' pause 500
' next i
' Main program loop
do
'Watchdog 40000 'reset after 40 secs on hang
'==============================Check Console and Serial Ports====================================
IF GetCon=1 then
ReadConsole
'If data in console1 then GOSUB GetConsole
END IF
IF GetCom1=1 then
ReadSerial1
'If data in COM1 then GOSUB GetSerial1
END IF
IF GetCom2=1 then
ReadSerial2
'If data in COM2 then GOSUB GetSerial2
END IF
' Procedures providing program functionality components
'Checks console and serial ports for data and sets flag if data has stopped coming in.
'flag triggers read of the data in the main program loop
sub IsSerialOrConsoleComplete
'Check console and set flag if data exists and has stopped coming in
loc0now=LOC(#0)
IF Loc0now>0 then
IF loc0now=loc0last then 'data finished
GetCon=1 'If data in CON then set GetConsole flag
else
loc0last=loc0now
ENDIF
END IF
'Check COM1 and set flag if data exists and has stopped coming in
' loc1now=LOC(#1)
' IF loc1now > 0 THEN
' if loc1now=loc1last then 'data finished
' GetCom1=1
' ELSE
' loc1last=loc1now
' ENDIF
' ENDIF
'Check COM2 and set flag if data exists and has stopped coming in
' loc2now=LOC(#2)
' IF loc2now > 0 THEN
' if loc2now=loc2last then 'nothin new
' GetCom2=1
' ELSE
' loc2last=loc2now
' ENDIF
' ENDIF
END sub
'Reads data from the console
sub ReadConsole
local char$
local integer i,j,k
j=
LOC(#0)
char$=
INPUT$(100,#0)
IF char$<>"" then
IF len(char$)=1 then
' ? char$;
' ? ASC(left$(char$,1));
IF Char$="0" then id=0
IF Char$="1" then id=1
IF Char$="2" then id=2
IF Char$="3" then id=3
IF Char$="4" then id=4
IF Char$="5" then id=5
IF Char$="6" then id=6
IF Char$="7" then id=7
IF Char$="8" then id=8
IF Char$="9" then id=9
IF Char$="a" then id=10
IF Char$="b" then id=11
IF Char$="c" then id=12
IF Char$="d" then id=13
IF Char$="e" then id=14
IF Char$="f" then id=15
IF Char$=chr$(145) then 'F1 VT100
? "F1"
END IF
IF Char$=chr$(146) then 'Home VT100
? "F2"
END IF
IF Char$=chr$(147) then 'Home VT100
? "F3"
END IF
IF Char$=chr$(148) then 'Home VT100
? "F4"
END IF
IF Char$=chr$(149) then 'F1 VT100
? "F5"
END IF
IF Char$=chr$(150) then 'Home VT100
? "F6"
END IF
IF Char$=chr$(151) then 'Home VT100
? "F7"
END IF
IF Char$=chr$(152) then 'Home VT100
? "F8"
END IF
IF Char$=chr$(153) then 'Home VT100
? "F9"
END IF
IF Char$=chr$(155) then 'Home VT100
? "F11"
END IF
IF Char$=chr$(156) then 'Home VT100
? "F12"
END IF
IF Char$=chr$(127) then 'up arrow VT100
? "Del"
END IF
IF Char$=chr$(128) then 'up arrow VT100
'? "Up Arrow"
IF highlow=0 then
ServoMIN(id)=ServoMIN(id)+
1
else
ServoMAX(id)=ServoMAX(id)+
1
END IF
END IF
IF Char$=chr$(129) then 'down arrow
'? "Down Arrow"
IF highlow=0 then
ServoMIN(id)=ServoMIN(id)-
1
else
ServoMAX(id)=ServoMAX(id)-
1
END IF
END IF
IF Char$=chr$(131) or Char$=chr$(4) then 'right arrow VT100 MMEdit
'?"Right Arrow"
SERVOSet(id ,180)
highlow=
1
END IF
IF Char$=chr$(130) or Char$=chr$(19) then 'left arrow VT100 VT100 MMEdit
'? "Left Arrow"
SERVOSet(id ,0)
highlow=
0
END IF
IF Char$=chr$(132) then
"INS"
END IF
IF Char$=chr$(133) then
"133"
END IF
IF Char$=chr$(134) then
"Home"
END IF
IF Char$=chr$(135) then
"End"
END IF
IF Char$=chr$(136) then 'PgUp VT100
IF highlow=0 then
10
else
10
END IF
END IF
IF Char$=chr$(137) then 'PgUp VT100
IF highlow=0 then
10
else
10
END IF
END IF
IF Char$=chr$(138) then
"138"
END IF
IF Char$=chr$(139) then
"ALT"
END IF
IF Char$=chr$(140) then
"140"
END IF
IF Char$=" " then
' ? "SPACE BAR"
SERVOSet(id ,90)
? id,ServoMIN(id),ServoMAX(id);
IF highlow=1 then
" High(180)"
else
" Low(0)"
ENDIF
ENDIF
else
? char$;
ENDIF
IF ASC(left$(char$,1))=27 then
"ESC"
END IF
END IF
END IF
END sub
' PCA9685 I2C PWM Routines
'Original Author:- Limor Fried/Ladyada for Adafruit Industries
'Ported to MMBasic by Disco4now!, TBS forums
' This is a library for our Adafruit 16-channel PWM & Servo driver
' Pick one up today in the adafruit shop!
' ------> http://www.adafruit.com/products/815
' These displays use I2C to communicate, 2 pins are required to
' interface. For Arduino UNOs, thats SCL -> Analog 5, SDA -> Analog 4
' Adafruit invests time and resources providing this open source code,
' please support Adafruit and open-source hardware by purchasing
' products from Adafruit!
' Written by Limor Fried/Ladyada for Adafruit Industries.
' BSD license, all text above must be included in any redistribution
sub SERVOSet(id as integer,angle as integer)
'set individual servo to desired angle
local integer tickoff
tickoff=
4096*(ServoMin(id)+(ServoMAX(id)-ServoMIN(id))*angle/180)/20000
'? tickoff
PWMSet(id ,1,tickoff)
END sub
sub PWMSetPin(id as integer,value as integer,inv as integer)
'Helper to set pin PWM output. Sets pin without having to deal with on/off tick placement
'and properly handles a zero value as completely off and 4095 as completely on.
'Optional invert parameter supports inverting the pulse for sinking to ground.
'id is PWM output pin, from 0 to 15
'value is the number of ticks out of 4096 to be active, should be a value from 0 to 4095 inclusive.
'inv if true, inverts the output, defaults to 'false'
'clamp value between 0 and 4095 inclusive.
IF value > 4095 then value=4095
IF value < 0 then value=0
IF inv=0 then
IF value=0 then
'special value for fully off
PWMSet(id ,4096,0)
else IF value=4095 then
'special value for fully on
PWMSet(id ,0,4096)
else
PWMSet(id,
0, 4095-value);
ENDIF
else
IF value=4095 then
PWMSet(id ,
4096,0)
else IF value=0 then
PWMSet(id ,
0,4096)
else
PWMSet(id,
0, value);
ENDIF
ENDIF
END sub
sub PWMSet(id as integer,ontick as integer,offtick as integer)
'main routine -sets the PWM output of one of the PCA9685 pins
' id - One of the PWM output pins, from 0 to 15
' ontick - At what point in the 4096-part cycle to turn the PWM output ON
' offtick - At what point in the 4096-part cycle to turn the PWM output OFF
i2c write PCA9685_ADDRESS,0,5,LED0_ON_L+4*id,ontick and &HFF,ontick >> 8 ,offtick and &HFF ,offtick >> 8
IF MM.I2C then ERROR "slave did not respond in PWMset"
END sub
sub PWMInit(freq as FLOAT)
'Select one of the following possible PCA9685 I2C Addresses in range 40-7F
'40 is default for no links on A5-A0 address pins.
'Call once at the start of the program with desired frequency to be used on all pins
dim integer PCA9685_ADDRESS = &H40 'default &H40 (&H40-&H7F)
dim integer PCA9685_MODE1=&H0
dim integer PCA9685_PRESCALE=&HFE
dim integer LED0_ON_L=&H6
dim integer LED0_ON_H=&H7
dim integer LED0_OFF_L=&H8
dim integer LED0_OFF_H=&H9
dim integer ServoMIN(16),ServoMAX(16)
'calibration values for each servo
ServoMIN(
ServoMIN(
ServoMIN(
3)=475:ServoMAX(3)=2050
ServoMIN(
4)=480:ServoMAX(4)=2160
ServoMIN(
5)=480:ServoMAX(5)=2160
ServoMIN(
6)=480:ServoMAX(6)=2160
ServoMIN(
7)=480:ServoMAX(7)=2160
ServoMIN(
8)=480:ServoMAX(8)=2160
ServoMIN(
9)=480:ServoMAX(9)=2160
ServoMIN(
10)=480:ServoMAX(10)=2160
ServoMIN(
11)=480:ServoMAX(11)=2160
ServoMIN(
12)=480:ServoMAX(12)=2160
ServoMIN(
13)=480:ServoMAX(13)=2160
ServoMIN(
14)=480:ServoMAX(14)=2160
ServoMIN(
15)=480:ServoMAX(15)=2160
i2c open 10, 100
'reset the PCA9685 to power on state
i2c write 0,0,1, &H06
IF MM.I2C then ERROR "slave did not respond at power eset"
PAUSE 1
'reset the PCA9685
i2c write PCA9685_ADDRESS,0,2,PCA9685_MODE1, &H80
IF MM.I2C then ERROR "slave did not respond at reset"
PAUSE 1
'set pwm frequency
IF freq=0 then freq=1000 ' set a default if not set.
PWMSetFreq(freq)
END sub
sub PWMSetFreq(freq as FLOAT)
'sets or changes PWM frequency.
'freq range 40-1000 hz
local integer mode1,GetData(1)
dim FLOAT prescaleval = 25000000/4096
dim integer prescale,currentmode
freq=freq *
0.9 ' Correct for overshoot in the frequency setting
prescale=INT((prescaleval/freq)-0.5)
i2c write PCA9685_ADDRESS, 0, 1, PCA9685_MODE1
i2c read PCA9685_ADDRESS, 0, 1, mode1 ' read current mode
IF MM.I2C then ERROR "slave did not respond 2"
i2c write PCA9685_ADDRESS, 0, 2,PCA9685_MODE1, mode1 or &H10 ' set sleep bit so change of scaler allowed
i2c write PCA9685_ADDRESS, 0, 2,PCA9685_PRESCALE,prescale 'set the prescaler
i2c read PCA9685_ADDRESS, 0, 1, GetData() ' read prescaler
IF MM.I2C then ERROR "slave did not respond 3"
i2c write PCA9685_ADDRESS, 0, 2, PCA9685_MODE1,mode1
PAUSE 1
i2c write PCA9685_ADDRESS, 0, 2, PCA9685_MODE1,mode1 or &HA0 'This sets the MODE1 register to turn on auto increment.
END sub
F4 H7FotSF4xGT
Frank N. Furter
Posted: 09:23am 03 Apr 2018
Hi Gerry,
thanks for sharing!!!
Frank
