Local Time 00:54 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme firmware update V5.4.09
Posted: 03:01pm 11 Jan 2018
Please find attached V5.4.08 for the 100/144 pin chips
2018-01-12_010028_MMX5.04.09.zip
and the 64-pin chips
2018-01-12_010110_MMX645.04.09.zip
This release contains the USER display driver Geoff has included in MM2 and MM+ versions 5.4.09.
Kabron
Posted: 01:41pm 10 Feb 2018
Board PIC32-EMZ64, serial connection via native USB.
ANSI escape sequences not work :(
Posted: 04:40pm 10 Feb 2018
  Quote  Board PIC32-EMZ64, serial connection via native USB.
If you mean you are connecting the Micromite direct as a CDC device then you should be aware that the expectation now is that you use an external USB UART such as the PIC16F1455 microbridge. The latest release of the Micromite eXTreme replaces the USB CDC functionality with USB HID HOST to allow connection of a USB keyboard.
Kabron
Posted: 08:20am 11 Feb 2018
Well, I made serial connection the same as latest release of the Micromite eXTreme via RF0/RF1 at 38400. It works but still no ANSI support.
Posted: 08:38am 11 Feb 2018
  Quote  It works but still no ANSI support.
What do you mean by ANSI?
Kabron
Posted: 09:03am 11 Feb 2018
If I undersand correctly, the microbridge does all work, related to ANSI interpretation?
Kabron
Posted: 01:29pm 11 Feb 2018
ansi escape sequences.
It is realized in Maximites.Edited by Kabron 2018-02-12
Posted: 05:34pm 11 Feb 2018
The MMX is based on the micromite not the maximite. I am still unclear what you are trying to do. The micro bridge just passes ASCII characters to the micromite. It does not interpret anything. If there is something the normal micromite does that the MMX doesn't then it is a bug otherwise it it not current scope.
