Local Time 20:54 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MP3 player for 50c.....
Posted: 04:48am 10 Jan 2018
Remember when MP3 player modules used to be $50 or more?
I do.
Now you can get a basic one for 50-cents, assembled, with uSD card slot.
50c MP3 player
Somehow for that price, they have even got a 2W audio amp on it, so hook it to a speaker, and away you go. For the price of these things, I just HAD to get a couple.
This is a very simple playback device, and does not even have a serial interface, just buttons on an ADC pin.
GDP2846 Datasheet (Chinese)
I will have a tinker with these things when they arrive, but for adding simple sounds or music to a project, you can't really get any cheaper then this!
EDIT: Datasheet after running it through Online Document Translator:
English attempt at datasheet
Some of the formatting is wrong in the translation, but you can certainly read more of the translated version then the Chinese version.Edited by Grogster 2018-01-11
Azure
Posted: 05:04am 10 Jan 2018
Plus an FM tuner on the board.
Posted: 05:28am 10 Jan 2018
I THINK you need an external FM radio chip if I decipher the Chinese datasheet correctly. I think there are a few supported FM radio chips it can talk to, but I don't think this is on-board.
Azure
Posted: 05:59am 10 Jan 2018
I had a reread and I think you are spot on (my mistaken assumption on reading the specs quickly). Given the board has 2 chips the main GDP2846 and another which I assume is the audio amp IC. Then the FM IC must not be loaded.
Posted: 10:42am 10 Jan 2018
I use(d) something similar but smaller in the feedback pods that work with my snooker/pool table controller. The pod has an mp3 player + audio amp to play fire-alarm message etc.
This might be nicer as it has everything onboard - will grab some and play
Boppa
Posted: 10:56am 10 Jan 2018
Jeez- it makes you wonder how they can make a profit at all at that price- surely even in bulk, the components have to be worth more than that...
Posted: 11:39am 10 Jan 2018
you'll often find some/many of the components used are end-of-reels, surplus, obsolete, or expired stock, available the the people making the boards for just the recyclable materials (gold/copper) value. this is why an assembled product may appear for just a few months, then never be seen again - once key components run out (and the manufacturer may only have a few thousand to start with) there is no ability to make more.
rob :-)
Posted: 09:55pm 10 Jan 2018
@ Boppa: My thoughts EXACTLY.
@ Rob: You probably have that right in this case.
