Local Time 20:54 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit thought.
Phil23
Posted: 09:37pm 04 Jan 2018
Hi All,
Really for Jim this one.
I often lose track of "What" I have in some of my MM's; bad practice on my part...
I am currently doing this, just creating a Variable at the start; Comments don't work, as they get killed by Crunch...
'MMEDIT!!! Basic Version = Micromite_Plus_V5.2
'MMEDIT!!! Port = 192.168.59.184:23:30,150
'MMEDIT!!! Device = Micromite_Plus_V5.3
'MMEDIT!!! Config = 100111120121010110000000000001
Dim String Version="1.04"
' System and DGP code for Micromite MMBasic
' Acknowledements : Geoff Graham Geoffg.net
' Using work licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Australia (CC BY-NC-SA 3.0)
' Written by REF, Phil
' Ver 1.0 21/03/17
' Ver 1.1 22/03/17 more code added - Review by Phil, clean up syntax
I understand what Jim is doing with the first 3 lines, but wonder about the addition of another right at the beginning of the code; basically another string variable, that would have to be unused, something like:-
[Code]Dim SwDate$="05/01/2017 - 8:31:00"[/code]
End result would be that the first line of code viewed in the editor would indicated when the code was loaded.
Could also go a step further add a path,
(Realise Length could have issues) & have:-
Dim SwPath$="G:\MicroMite Stuff\Code\Phils Code\Ceiling Heat Controller-DGP 1.04.bas"[/code]
Don't even know if it's a good idea or not, just thinking out loud.
Only real perpose would be their visibility in the internal editor, especially when the code is crunched.
Phil.
Edited by Phil23 2018-01-06
Posted: 11:15pm 04 Jan 2018
REM this will stay forever
MMEdit only crunches lines with a single quote remark, it leaves REM's alone
Phil23
Posted: 10:04am 05 Jan 2018
Ahhh,
Thanks Jim,
Think my brain cells with REM in them died in the early Windows Days.
Phil
