Local Time 20:54 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Some light reading for the New Year
BrianP
Posted: 04:42am 01 Jan 2018
Happy New Year shedders!
Aplogies for this longish post
Given this is the season for relaxation & idle moments - I share my current project of the door entry routine for the local public hall.
If anyone could find the time to peruse & advise of any danger lurking in the code (still in development) I would be eternally grateful.
My programming skills are anal at best - functionality beats efficient code, but I do ultimately aim for best practice (ageing brain - 75 this year. It
seems a long while since the Commodore basic programming days of the 70s).
There is an original working base version of this program running on a colour Maximite (proof of concept) which was developed in a big hurry & installed
as an emergency temporary fix when the existing proprietry hardware went past its use-by date & required in excess of $1100 AU to be replaced (7x5cm
circuit board with a PIC & peripherals!). The Maximite is working fine, but we don't have the ability to remotely modify program code or update the entry
codes database.
This current project runs on one of Grog's/Rob's marvellous E28 boards, with added power, RTC & RS232-TTL modules, plugged to a hardware interface board
(done on veroboard as a once-off). We use 2 E28 ports to drive the keypad status LED & toggle the R/G LED polarity.
The hardware setup consists of an external numeric entry keypad with a R/G status LED & piezo beeper, battery backed 12v power supply, RS232 connection
to an Internet connected Win 10 laptop for remote entry codes & program updates, relay interface to control the the door lock/unlock. As is commonly the
case the door has its own IR entry movement detection, operational when unlocked. Once again, the interface board is a veroboard item (one-off). By the
time one works out the hardware layout & interconnects it doesn't seem to be worthwhile to do a nice custom circuit board for a one-off project, although
it would save heaps of jumper connects.
Before Grogs gets too nervous about Win 10 the Internet connection is cellular & doesn't do auto updates (verified to be so - at the moment).
The remote connection allows maintenance of the valid entry codes database on a dynamic basis, & and program tweaks as we all know is a never-ending
feast. I have used the console connection rather than a conventional com port for the serial access so as to allow remote program updates which can only
be done when the program is not running.
On the laptop we run a couple of very simple DOS MMbasic routines which allow on-demand update of the current entry codes list & a timed periodic
download appended to a text file of the the current entry log.
Entry of door access codes via the external keypad is normally a 4 or 5 digit number terminated by a hash, but up to 10 digits are accepted (as in the
default emergency code). This code exists in case the current codes list is not yet updated after a restart & is replaced by the current codes list.
Any questions happily answered...
B
'FWMAC.bas v.5.11 <c> BCP 2018-01-01 for Micromite MK II E28
'Program to read keypad input, check against array of valid codes, lock or unlock door
'reserved pins unavailable for program - 1,8,11,12,13,17,18,19,20,27,28
'Keypad rows 1-4 on pins 2-5, columns 1-3 on pins 6,7,9
'pin 26 = digital Door control relay out (contacts N/C - relay not energised for door locked)
'Pin 25 = digital BEEP out for beeper transistor switch
'pins 21,22 = KEYLED polarity swap outputs for green/red LED
'pins 17,18 = RTC
'pin 14 = digital oc door not closed (dnc) switch 5v
'free pins 15,16 5v tolerant, 10,23,24 3.3v only
'Comms: if 1st chars received are "*"+chr$(13) then next data is valid$() codes list terminated by "*"
'Comms: if 1st chars received are "%"+chr$(13) then send event log terminated by "%"
'Comms: if 1st chars received are "?"+chr$(13) then send current codes list
'Comms: if 1st chars received are "^"+chr$(13) then send door status
'Comms: if 1st chars received are "["+chr$(13) then lock door
'Comms: if 1st chars received are "]"+chr$(13) then unlock door
option explicit:option base 0:option clocktrim -4: ''' option autorun on
dim edate$, update, remotelock, sendevent, uc, padkey$, press, remoteunlock, lockstatus, delog, csec, esec
dim success, logcount, invalidcount, hash, hsh$, key$, lock, firstrun, a, keycode, status$, scodes, con$
const doorlock=26, beep=25, dnc=14, led1a=21, led1b=22, led2a=23, led2b=24, cmax=999999
edate$="":update=0:remotelock=0:remoteunlock=0:sendevent=0:uc=0:scodes=0:remoteunlock=0:lockstatus=0
padkey$="":timer=0:press=0:success=0:logcount=0:InvalidCount=0:hash=0:Key$="":lock=0
pin(doorlock)=0:setpin doorlock, dout:lock=1 'door lock relay (1=open, 0=locked)
pin(led1a)=0:setpin led1a, dout 'keypad LED Green (Bi-colour LED toggle)
pin(led1b)=0:setpin led1b, dout 'keypad LED (Red) (Bi-colour LED toggle)
'pin(led2a)=1:setpin led2a, dout 'keypad LED Green (Bi-colour LED toggle)
'pin(led2b)=0:setpin led2b, dout 'keypad LED (Red) (Bi-colour LED toggle)
pin(beep)=0:setpin beep, dout 'beep (1=beep, 0=off)
pin(dnc)=0:setpin dnc, oout 'dnc switch detect
dim valid$(99) length 51 'list of valid entry codes
dim event$(99) length 90 'event logging & door status with date/time stamp
settick 4*3600000, settime, 4 'set clock every 4 hours
settick 1000, SECS, 3 'start seconds counter csec
ENTRY 'call keypad enable
'''''''''''''''''''''''''''''''''''''''RTC gettime 'currently not connected
for a=0 to 99:read valid$(a):if valid$(a)="*" then valid$(a)="":a=99 'load whatever inbuilt codes exist
next a
padkey$=" | controller started | FWMAC.bas v.5.11":firstrun=1:ADDLOG :padkey$="":VALIDBEEP :LEDRED
do 'main program loop
START:
CONSIN
if press>10 then INVALIDENTRY :ADDLOG :timer=0:LOCKOUTBEEP :press=0:padkey$="":goto START 'too many keypresses
if hash=0 or padkey$="" then goto NOPRESS 'no keypad entry - check for control codes
VALIDCHECK
if success then VALIDENTRY :TOGGLELOCK :ADDLOG
RESET:
if not success then INVALIDENTRY :ADDLOG
padkey$="":success=0:hash=0 'add to log, reset ready for next attempt
NOPRESS: 'input not 0 - 9
if press>0 and timer>5000 then press=0:success=0:goto RESET 'key press but no # for 5 sec
' other tasks not related to keypad entry
if sendevent=2 then SENDLOG :sendevent=0
if scodes=2 then SENDCODES :scodes=0
if update=2 then VALIDUPDATES 'do codes update
if remotelock=2 then lock=0:padkey$=" | Remote Lock Override ":TOGGLELOCK :ADDLOG :remotelock=0:padkey$=""
if remoteunlock=2 then lock=1:padkey$=" | Remote Lock Override ":TOGGLELOCK :ADDLOG :remoteunlock=0:padkey$=""
if lockstatus=2 then padkey$=" | Remote Lock Status Read ":ADDLOG :remotelock=0:padkey$="":lockstatus=0
if delog=2 then deletelog :delog=0
a=sendevent+scodes+update+remotelock+remoteunlock+lockstatus+delog:if a and timer>5000 then RESETVAR
loop 'start over
end
sub ADDLOG
if lock then status$="locked"
if not lock then status$="unlocked"
DATESWAP :event$(logcount)=edate$+" | "+time$
if firstrun=1 then firstrun=0:event$(logcount)=event$(logcount)+padkey$+" | door "+status$:? event$(0):logcount=1:exit sub
if remotelock>0 or remoteunlock>0 or lockstatus>0 then event$(logcount)=event$(logcount)+padkey$+" | door "+status$:DOLOG :exit sub
hsh$="":if not hash then hsh$=" | No hashkey"
if success then event$(logcount)=event$(logcount)+" | Granted | "+padkey$+" | door "+status$
if not success then event$(logcount)=event$(logcount)+" | Denied | "+padkey$+hsh$+" | door "+status$
DOLOG 'increment log
end sub
sub CONSIN
con$=inkey$:if con$=chr$(13) then CONCHK :exit sub
if con$="*" then update=1:esec=csec 'start timeout count
if con$="%" then sendevent=1:esec=csec
if con$="?" then scodes=1:esec=csec
if con$="[" then remotelock=1:esec=csec
if con$="]" then remoteunlock=1:esec=csec
if con$="^" then lockstatus=1:esec=csec
if con$="&" then delog=1:esec=csec
if con$="#" then hash=1
if asc( con$)>47 and asc(con$)<58 then padkey$=padkey$+str$(val(con$)):press=press+1 'numeric key entry
timer=0
end sub
sub CONCHK
if csec-esec>2 then RESETVAR:exit sub 'more than 2 sec since last entry, ignore & cancel
if update then update=2
if sendevent then sendevent=2
if scodes then scodes=2
if remotelock then remotelock=2
if remoteunlock then remoteunlock=2
if lockstatus then lockstatus=2
if delog then delog=2
end sub
sub DATESWAP
edate$=right$(date$,4)+mid$(date$,3,3)+"-"+left$(date$,2)
end sub
sub DELETELOG
local a:for a=0 to 99:event$(a)="":next:? "Eventlog deleted."
end sub
sub DOLOG
? event$(logcount)
if logcount<99 then logcount=logcount+1
if logcount=99 then logcount=0 'go round again & overwrite if array full
end sub
sub ENTRY
keypad KeyCode, KP_INT, 2, 3, 4, 5, 6, 7, 9
? "keypad enabled"
end sub
sub INVALIDBEEP
pulse beep, 2000
end sub
sub INVALIDENTRY
invalidcount=invalidcount+1:if invalidcount>6 then LOCKOUTBEEP :pause 5000:invalidcount=0 'lockout for 5sec
INVALIDBEEP :press=0:'? "INVALID ENTRY"
end sub
sub KEYBEEP
pulse beep, 20
end sub
sub KP_INT
if KeyCode=11 then hash=1:if press=0 then hash=0
if keycode<10 then padkey$=padkey$+str$(KeyCode):Key$="":press=press+1:timer=0
pulse beep, 100
end sub
sub LEDGREEN
pin(led1a)=0:pin(led1b)=1
end sub
sub LEDRED
pin(led1a)=1:pin(led1b)=0
end sub
sub LOCKOUTBEEP
pulse beep, 5000
end sub
sub PRINTLOG
local a:keypad close:for a = 0 to 99:if event$(a)>"" then ? event$(a):next:ENTRY
end sub
sub RESETVAR
sendevent=0:scodes=0:update=0:remotelock=0:remoteunlock=0:lockstatus=0:delog=0:esec=0 'key entry timeout
end sub
sub SECS
csec=csec+1:if csec>cmax then csec=0
end sub
sub SENDLOG
local a:keypad close:for a=0 to 99:if event$(a)>"" then print event$(a):event$(a)=""
next a:print "%":sendevent=0:ENTRY
end sub
sub SENDCODES
local a:keypad close:for a=0 to 99:if valid$(a)>"" then ? valid$(a)
next a:scodes=0:ENTRY
end sub
sub settime
'''''''''''''''''''''''''''''''rtc gettime
end sub
sub TOGGLELOCK
lock = not lock:pin(doorlock)=lock:if lock then LEDRED else LEDGREEN
''''if not lock then LEDGREEN
end sub
sub VALIDBEEP
pause 500:pulse beep, 100:pause 150:pulse beep, 50
end sub
sub VALIDCHECK
local a:success=0:for a = 0 to 99 :if val(valid$(a))=val(padkey$) then success=1:padkey$=valid$(a):a=99
next
end sub
sub VALIDENTRY
press=0:VALIDBEEP :'? "Entry Valid"
end sub
sub VALIDUPDATES
keypad close 'temporarily disable keypad during codes update
for uc=0 to 99:valid$(uc)="":next:uc=0:timer=0:? "Ready to receive codes..."
do while valid$(uc)<>"*"
if timer>10000 then uc=0:update=0:? "Codes timeout!":ENTRY :exit sub 'timeout after 10 seconds if not completed
line input valid$(uc)
if valid$(uc)="*" then uc=0:update=0:? "Codes receive finished":ENTRY :exit sub 'update done
if uc<99 then uc=uc+1
loop
end sub
data "0356822077 Default Emergency Code","*"
Posted: 07:01am 01 Jan 2018
[Quote]Before Grogs gets too nervous about Win 10.......[/Quote]
Who said I was nervious about Windows 10?!
W10 seems OK if you:
1) Run on certified compatible hardware
2) Turn OFF all that guff that runs around the edges of it.
My little Acer notebook PC runs very well on W10, but I did have to spend an afternoon turning off or otherwise disabling a whole plethora of background services and programs. That done, it is not too bad. I just pity Joe/Jo Bloggs who has to deal with the default install hogging all the PC resources.
......oh dear......you might have triggered me after all.....
BrianP
Posted: 07:19am 01 Jan 2018
You got it!
