Local Time 00:55 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme firmware update V5.4.08
Posted: 12:53pm 27 Dec 2017
Please find attached V5.4.08 for the 100/144 pin chips
2017-12-27_225248_MMX5.04.08.zip
and the 64-pin chips
2017-12-27_225212_MMX645.04.08.zip
This release contains all the bug fixes Geoff has included in MM2 and MM+ versions 5.4.08.
panky
Posted: 03:17am 28 Dec 2017
Peter,
Thanks for the great work - up and running on on my Extreme 144 and all seems well.
Cheers,
Doug.
Kabron
Posted: 01:53pm 31 Dec 2017
Hello,
I tryed to use this FW with Olimex PIC32-HMZ144 board.
After successful flashing nothing happened.
I see no oscillation on both crystals(I changed main crystal to 24 MHz).
I also tryed to supply external 24MHz clock with no result.
Finaly, I tryed to compile the source code with MPLAB X IDE 4.05 and XC32 1.44 and Harmony 2.05.
Got huge amount of errors of losted files.
Any ideas appreciated.
Edited by Kabron 2018-01-01
Posted: 03:23pm 31 Dec 2017
That board appears to use an ECG chip. MMX code will only run on EF chips (these have HW floating point). See the manual for valid chips.
You can only compile the code under an environment with Harmony 2.02b installed and all the directory references properly resolved.
Kabron
Posted: 03:52pm 31 Dec 2017
  matherp said   That board appears to use an ECG chip.
It is! I did not notice :(
Thanks a lot
Kabron
Posted: 03:58pm 31 Dec 2017
So, I guess that PIC32-EMZ64 with PIC32MZ2048EFH064 will be OK.Edited by Kabron 2018-01-02
Posted: 04:26pm 31 Dec 2017
  Quote  So, I guess that PIC32-EMZ64 with PIC32MZ2048EFH064 will be OK.
No - not really. It uses completely different pins for things like the SDcard to the MMX code. You would be much better with either a very simple board with all of the I/O available or one of the PCBs I've specifically designed.
See this thread and this thread for details. I don't make/supply them but you can get them off WhiteWizzard in various levels of completion or just bare boards - just send him a PM
Kabron
Posted: 12:32pm 10 Feb 2018
Just flashed PIC32-EMZ64 with MMX645.04.09 and obtain console output.
After resoldering 3 SDCARD wires got SD working.
