Local Time 19:52 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI AREA overlaying DISPLAYBOX
panky
Posted: 01:46am 04 Dec 2017
I have been trying to create some Display Boxes with text but have them respond to touch (yes, I know a basic Display Box does NOT respond to touch), so I created an area using GUI AREA that overlays the same area as the DisplayBox so I could catch the touch.
The area defined by the DisplayBox however seems to blank out any touch within that area.
I made the AREA command slightly larger than the DisplayBox to test - if you touch just outside the DisplayBox it works but inside the area defined for DisplayBox ,nothing.
Can anyone advise if this is a bug or just a limitation of the GUI commands?
Tested on a MM+ with ILI LCD and an MM Extreme with SSD display, both running 5.04.05.
Test program below
Const DBox1 = 1
Const DBox2 = 2
Const LED1 = 21
Const LED2 = 22
Const AREA1 = 31
Const AREA2 = 32
' Initialise
pwm 2,1000,50
gui interrupt TouchDown
cls rgb(60,60,30)
font 2,2
gui Displaybox DBox1,10,10,100,50,rgb(green),rgb(120,120,100)
gui Displaybox DBox2,10,80,100,50,rgb(blue),rgb(120,120,100)
gui area AREA1,0,0,120,70
gui area AREA2,0,70,120,70
gui led LED1,"",160,35,20,rgb(RED)
gui led LED2,"",160,105,20,rgb(RED)
'Main program loop
ctrlval(LED1) = 1
ctrlval(LED2) = 0
ctrlval(DBox1) = "DB 1"
ctrlval(DBox2) = "DB 2"
do
pause 2000
loop
' Interrupt service routines
' Touch Down
sub TouchDown
select case Touch(REF)
case AREA1
ctrlval(LED1) = 1
ctrlval(LED2) = 0
case AREA2
ctrlval(LED2) = 1
ctrlval(LED1) = 0
end select
end sub
pankyEdited by Gizmo 2017-12-08
panky
Posted: 03:26am 05 Dec 2017
Further to my previous post, I can confirm that the GUI AREA is NOT masked by the GUI LED command - that is, even though the GUI LED is not touch sensitive, you can make it so with the GUI AREA command to cover the same area as the LED.
To my mind, there is an inconsistancy there which appears to be a bug.
panky
Posted: 07:47am 05 Dec 2017
Interesting problem. When the screen is touched MMBasic will check the list of controls to determine if the touch is within the bounds of a control and, if it is, deals with it appropriately - which in the case of a DISPLAYBOX is to ignore the touch. Once a control has been found the scan is terminated.
The scan is made starting with control number 1 and increments upwards. So, if you made the control number of the AREA control less than the number for the DISPLAYBOX, the AREA control will be found first and that is what will respond to the touch.
I will update the documentation accordingly.
panky
Posted: 02:06am 06 Dec 2017
Thanks Geoff,
understood.
panky
Azure
Posted: 02:18am 06 Dec 2017
Is it just me or is this forum page corrupted somehow?
Starts off normally but then at the first signature block it loses the layout info and everything after that is on the page background.
*edit: actually it might be something in the end of the embedded code/image.Edited by Azure 2017-12-07
Posted: 10:06am 06 Dec 2017
  Azure said   Is it just me or is this forum page corrupted somehow?
no and yes
Edited by CaptainBoing 2017-12-07
Posted: 10:22pm 06 Dec 2017
Yes, it is all wonky.
Posted: 11:40pm 06 Dec 2017
Fixed it, thanks for heads up Azure. Panky's code confused the forum display subroutines. There was a bunch of forum formatting tags mixed in there, a QUOTE tag caused the problem. No one's fault.
panky
Posted: 02:50am 07 Dec 2017
Glenn,
I think what I did wrong was take some MMEdit 'Formatted for TBS' code and pasted it in between Code delimiters - I re-read Jim's post and he says, and I quote -
File menu: You can also copy a code selection to the clipboard formatted to produce colour code on TheBackShed forum. Highlight your code, File/Format for TBS and go to the forum, Paste. The QUOTE markers are automatically added. Hopefully I have allowed for all the usual gotcha’s that upset the forum formatting.
Apologies,
panky
