Local Time 17:46 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ascii text file
isochronic
Posted: 03:08pm 29 Nov 2017
Considering the use of text files to store data readings etc as text -
I am wondering, will an ascii file (text only) ever contain null bytes ?
Posted: 03:23pm 29 Nov 2017
CHR$(0) is generally a perfectly valid character however they are sometimes interpreted before your code gets a sniff at them; for instance in C they terminate a string and if you really want to work with them it can be tricky.
I would experiment by creating a file full of 0x00 characters (ASCII NUL) then read it back and see what I got.
Out of interest, what platform is this? might help to define answers. Interesting that MMBasic V5.04.04 won't accept any number character under 32 in the STRING$() function - I don't like that as it rules out the ASCII control characters - I think this might have been covered before. Assigning a variable to CHR$(0) is fine though.Edited by CaptainBoing 2017-12-01
twofingers
Posted: 06:19pm 29 Nov 2017
In my understanding, it's a question of definition. What is a "text" file?
Generally I would say that a (ASCII) text file should not contain CHR$(0). No control characters also.
isochronic
Posted: 07:03pm 29 Nov 2017
The background is, I have made a widget that reads SD card files and makes the
content available via a standard spi connection. It is working ok however
it would be good to have a end-of-file-reached flag so that when a user tries to
read more data than a file contains, in error, it is handled properly.
A not-wonderful but simple way would be be to return a null to the spi read,
which depends on the file never having a null. But I guess it really should
use an extra connection to the main device, for control/feedback etc. It would be good to avoid an extra wire though.
(added) another option would be to send each byte using extra bits, maybe 16 bit.
Which would slow it down and need extra handling at the receive, hmm.Edited by chronic 2017-12-01
Posted: 07:47pm 29 Nov 2017
  twofingers said   In my understanding, it's a question of definition. What is a "text" file?
I see what you are getting at - a "text" file should contain printable characters only... what about CR & LF?
but you are right... "text" is a conceptual thing - it's all numbers at the end of the day, just how you interpret them that applies the model.
Posted: 08:00pm 29 Nov 2017
Programs such as XMODEM will add end-of-file characters to the end of the text to pad the file size to a 128 byte boundary. This is left over from the CPM days.
This end-of-file character can be either CTRL-Z or zero according to the XMODEM standard and I have seen both used.
Some terminal programs quietly drop any zeros, others don't.
I would play safe and assume that there might be zero bytes in any text file.
CR LF etc including CTRL-G (bell) and many others may be present.
If you create the file, you obviously have full control over the contents but if it is intended for general use, anything goes...
twofingers
Posted: 08:24pm 29 Nov 2017
You are correct!
Posted: 12:00pm 30 Nov 2017
MMBasic is happy writing and reading any character from 0 to 255 (decimal). Your experience with other systems reading the files can vary.
