Local Time 19:18 24 Oct 2026 Privacy Policy
Forum Index : EV's : AC motors
praxidice
Posted: 12:01pm 18 Jul 2013
Why are AC motors so ridiculously expensive ?? They don't look particularly complicated, seems to me that a tribe of halfway switched on folk could build the things at a mere fraction of whats being asked for them at present.
tomqu7
Posted: 10:04pm 15 Aug 2013
BYLONG QUOTED ME JUST OVER 5 K FOR A CURTIS WITH CONTROLLER
FOR A HOLDEN COMBO VAN
I AM NOT SURE IF IT WAS A 9 INCH
praxidice
Posted: 11:18pm 15 Aug 2013
  tomqu7 said   BYLONG QUOTED ME JUST OVER 5 K FOR A CURTIS WITH CONTROLLER
Whats wrong with 415 volt 3 phase industrial motors ?? There must be zillions of those available & given the number made, they should be available cheap ?? I believe a few conversions have been done using these motors so it appears its not impossible.
praxidice
Posted: 01:09pm 17 Aug 2013
http://www.bylongind.com.au/curtis_optional_items_&_spare_pa rts.html
AC-50 EV Conversion Kit
AC-50 AC Motor 8.5"x15" 7/8" shaft
Curtis 1238 controller
Curtis 840 LCD Gauge
Wiring loom
Price: $6325.00
Certainly a lot more attractive than what I've been quoted elsewhere, however I'm still leaning toward a Prius conversion based on the following numbers which I believe are correct. A base car (depending on age) is worth $10 - 15000, plug-in conversion & extra batteries another $15000, means total cost is $20 - 25000 for something thats got all the bells and whistles, can supposedly go 200k in EV mode & has its own range extender. I plan on checking out 'The Roadie' http://www.road-e.com.au/ which is an interesting if aircraft inspired thing built in Ballina. Mind you at $30,000 it strikes me as overpriced for whats little more than a three-wheeled motorbike.
